8-High MOD - HEADLIGHTS
Rollin Thunder
Banned for Repeatedly Insulting Members
Va Beach Va
for the DRLs, i simply took an old pair of 9005 bulbs that i used to have in my headlights before i got the xenarcs, how would i go about getting fog beam 9005s?
I have got no idea. A custom cut reflector/ but im sure as shit that cant be made easilly. But I thought you were talking about behind your grill??
danimalmax
louisiana
my bad, well the grill lights are h3 bulb driving lights that i picked up from autozone, cheap? yes. i was just gunna convert them to hid though
Rollin Thunder
Va Beach Va
How did you fit 9005 in the DRL?
Take the old bulbs out. Strip and wire tie, or solder, a 9005 socket on the drl wires (same gauge as the headlights I will add), and then modifty the bulb to fit in the headlight.
danimalmax
louisiana
yeah its quite simple, its a good thing the bulb fits through the hole too, so u dont have to dremel it or anything
withac
Eastern Idaho
Okay, maybe I'm a little slow here, but I'm not seeing exactly how to do the 8-hi mod. I've got a 2000 and I've already done the two mods to give me the 6-hi, what do I do to get the DRL's to stay on as well.
So RT, you have regular headlight bulbs in your DRL's? Do they run too hot for the housing and lense or are there any other problems?
BlizzardX23
BlizzardX23
Sacramento, California
Im not exactly sure bout the pre-2003 models..however, if you have a "DRL" relay, use another diode to connect your lowbeams to the DRL..thats how I did it
danimalmax
louisiana
yea dont u have to jump the wires together for the pre 2003 models? i did the diodes on the relays as well
withac, i have high beam bulbs in my drls, it might be too hot, but its been okay so far cause i just turn them off when i drive during the day, i only wanted it for more lights when i turn my high beams on
MikeTheApeman
The armpit of America - New Joisey
It really depends on your headlights. A 9005, 9003, h3, h1, 9006, 9007, 9008, etc. When were talking HID, are all THE SAME BULB, just a different base.
That's not exactly correct.
http://www.retrosolutionsllc.com/servlet/the-310/DIGITAL-HID-XENON-CONVERSION/Detail
Scroll down, these are the guys that did the conversion in my GC, and they have an H3 mini HID bulb kit that might work better in H3 lights, since the focal point stays the same. Similar to how HIR bulbs keep the focal point the same as halogens.
Issue is they are a bit pricey compared to DDM, but I would not hesitate to recommend Todd and Co. The work they did on my GC lights to retrofit Valeo projectors in was outstanding.
Rollin Thunder
Va Beach Va
Retro solutions is the only place I have found to be able to make that though. Which is why I didnt mention it since he likes DDM. BUt I have also used retro solutions and while more expensive. I feel the lighting components are better quality.
withac
Eastern Idaho
Thanks. The more I think about it I don't think I'll mess with it. I replaced the stock bulbs with Silverstar Ultra's so I have a pair of hi's and lo's I was thinking of trying it with. I'd want them on all the time though and I'd hate to melt the housing or distort the lense. Plus, the stockers would be more yellow than the SS's
MikeTheApeman
I agree, but figured it was worth putting out there that an alternative exists. I mean, in theory you could order the H3 mini bulbs from Retro and change the connectors out to work with DDM's hardware. I just think those bulbs would be better suited to an H3 housing than rebased HID bulbs.
And for the record, I've got DDM HID's in my Tahoe, and no real complaints about the Raptor kits so far. If I had to complain, I'd say that they take a minute to hit full brightness, whereas the ones I have from Retro are bright as can be as soon as they are turned on. Might be because I have a harness in the Money Pit (aka Grand Cherokee), just have to find time to install the harness in the Tahoe to see if that solves my problem.
Rollin Thunder
Va Beach Va
I like retro solutions customer service better as well. I had a couple questions about install and I e-mailed him at about 11:30 my time, expecting an answer sometime the next day, no in 20 min he responded. I still have his kit in my garage. I just cant use it because its a 9007 and I dont have a vehicle that takes that.
MikeTheApeman
Todd is great. I emailed him asking about a fog light kit and didn't know off the top of my head what I had put in the Jeep (35w or 55w). He answered me back in about 20 minutes, and even was able to tell me a year later what was installed.
jmildoc
Indianapolis,Area
How did you do the 6 HI????? I tried the diodes and it blew my relay!
withac
Eastern Idaho
moto
