Where to tap into "courtesy" power...
Physh1
I'm looking for a good place to tap into the courtesy power. I know I can tap into the harness from the door but I'm wondering if there may be a slightly easier to access power for that.
I'm running led strips for footwell lighting so when I open the door or hit the unlock on my key fob I'd like them to light up.
Any recommendations other than the door harness?
Cameron
Rivieraracing
For the footwells, do you have a light at the rear bottom of your center console? If so, that would be a good spot, just an idea of course!! I do in my truck but mine is an '02 denali so don't know if yours would be different!
Physh1
Physh1
I heard some have 194 bulbs there but I'm not one of them. I looked thinking the bulb may just be out but no luck...
Cameron
Rivieraracing
You lost me, are you saying that you have the light I mentioned but the bulb is out or were you thinking that I was saying to use that light for your footwells? If you have that light, you could tap into that wire and use it for your footwells, would be easy for your situation!
Physh1
Physh1
Sorry for the confusion.
I have no lights under the dash to tap into.
tsb09000
Thread Killer
I did this exact thing probably a year ago and it worked great using this as a guide. I used blue led strips to match my blue led bulbs everywhere else. I didn't even have to mount the passenger side, it's just wedged between the heater box and interior panel.
Rivieraracing
Hope this clears up what I am trying to say!!
Do you have this light at the bottom of your center console? If so you could tap into its power to run your footwell lights!!
Physh1
Physh1
Ok, now I get it...lol...
No, I don't have that...I just have cup holders there...no light...
---------- Post added at 12:45 PM ---------- Previous post was at 12:43 PM ----------
:Handshake:Thank you sir! Now I know what to do...
Rivieraracing
That's too bad that there's no light there, must be a denali thing, I wasn't sure! Other place you could pull power from is the map lights or dome lights in the roof but that might be kinda far! Sorry, wish I could have been more help!!
AdrienR
