Electric water pump...
99Yuk
Northern Ontario, Canada
Dang that E-WPump is interesting!
Where did you buy it? Part#?
How many amps does it draw?
Not worried about a wiring failure on the road?
Didn't do UD pulleys while in there?
Can you feel a difference in the Butt-O-Meter?
Very interesting....
foreverfalcon40
I hope you bought two, b/c if it poops out what are you going to do?
I was thinking of doing the same, but the worry for the HP doesn't seem like enough to warrant it.
retorq
retorq
Kingman AZ
I'm on my gauges like a hawk, I know there is a problem before there is a problem. LOL
It's like a new truck. Even when cold it gets up and f*ckin moves. I think that old pump had a bad bearing or something.
I got a Proform with relay kit from Jegs. It comes as a kit. I used their efan harness which is basically the same kit as for the water pump except for the temp sensor.
If your belt driven pump fails what are you gonna do?? The same thing I will do. Park it and get a new one. :D
Not sure of the amps but with just the pump the alternator is fine. With both efans, pump and the heat on full blast it dips down a lil. The voltage meter on my cap says mid 13s.
I should have done pulleys while there. Didn't have the money ... :emotions122:
99Yuk
Cool! Sounds like you got it covered.
I went to jegs and found THIS, but the vehicle applicator shows it only fits up to year 1995.
So then I went to the manufacturers webpage HERE, and it doesn't even have a vehicle applicator.
So what year is your truck and do you have a part number of the kit you bought?
So far I think you bought Proform part #66225B. If so, it only draws 6 amps which is peanuts. Factor on 1HP used to turn the ALT for every 10amp draw. So this electric pump draws 0.6hp from the engine, which is why it's so much better then the OEM.
EDIT: Man I love this place. Where else can you find extra HP with a little $160 mod? I didn't even know this stuff existed until joining here!
retorq
retorq
Kingman AZ
http://www.jegs.com/i/Proform/778/66225BK1/10002/-1
That is the kit I bought. My truck is a 95 ...
This is the EFan kit I got incase anyone else is interested:
http://www.jegs.com/i/JEGS+Performance+Products/555/10560/10002/-1
Some pics of the install ...
Mounted the water pump relay up with the factory ones:
Water pump wiring:
Forgot to pick up some fuse taps ... they are on the way...
I'll find the pics of the fan setup and post those ones as well ...
99Yuk
Water pump wiring:
Ok, thanks for confirming the year. That sucks for me. I can't find one for the vortec anywhere.
Good for you though!
retorq
retorq
Kingman AZ
I wonder why no Vortec listing ... the Vortec is externally the same as a std Gen 1 SBC ... I have one on a stand at home. Nothing special ...
99Yuk
Stewie, could you provide a link please? I tried searching 99 Yukon electric water pump HERE, and all I got was a mr. gasket universal electric water pump with pulleys and such. Nothing specific for the vortec.
---------- Post added at 07:42 AM ---------- Previous post was at 07:40 AM ----------
IDK, but I can't anything specific to a vortec. There must be some peice of something on the block that sits in the way of the pump that stops it from mounting like the TBI's.
BigDaddy13440
Rome, NY
Here is the blue one:
http://www.summitracing.com/parts/CMB-12-0007/
What seems to kill the application fit is using gmc yukon instead of chevy tahoe. Since you have the yukon call Summit with their part number and find out why it won't crossover.
I did it by year, and by engine size. For my '96 with a 5.7, I got this:
http://www.summitracing.com/search/Part-Type/Electric-Water-Pump-Combos/Liter/5-7/Year/1996/?Ns=Rank|Asc
---------- Post added at 09:40 AM ---------- Previous post was at 09:36 AM ----------
I used the Link I posted, tried every year from '91 to 2002, the same results came up. Apparently, there is NO difference for a water pump from a TBI setup to a Vortec.....
99Yuk
Just to throw more mud in the water.
I found THIS at Summit.
It's a Proform manufacturer water pump. Says it's good for years 67-00. Look at the details though. It's not good for a motor with a serp belt!
So I looked at the links provided by you guys. Both sets of water pumps are Summit branded, and the manufacturer part numbers are summit numbers as they don't show up in google anywhere else. Take a look at the pics, they look like the Proform manufacturer WP's.
So what gives.
I've sent an email to the manufacturer of all these kits, Proform asking for clarification.
EDIT: I took SunlightComet's advise and called up Summit. Talked to a guy named Larry. We talked about the Summit rebranding, it was confirmed that it was Proform's electric water pump. And we confirmed that those pumps are not for use with a vortec. It's because the vortec has some sort of bracket or something attached to the OEM pump that these ones don't have. Thus no vortec application for me.
EDIT 2:
My current vortec water pump:
Retorq's electric water pump:
Does anyone see a difference?
retorq
retorq
Kingman AZ
Yep, your heater return hose is on the other side from a "traditional" SBC water pump ... not seeing a bracket though. The Vortec engine I got was a short block so I can't say for sure what bracket is different. The other major difference is the roller block, you need "something" to hold the cam in. The factory roller stuff has a retainer plate, lots of aftermarket kits will use a bolt hung from a spot on the water pump ...
steamroller
The South
It's the external bypass that's different. That's what the extra hose that comes out from the lower intake to the water pump is for. You can "T" into the heater hose or drill the bypass in the block.
foreverfalcon40
Sell you mine $70 shipped with belt!
SunlitComet
OBS Jedi-Do Good
unknown at this time.
To add the idler and tensioner have traded places. As far as brackets the left and right accessory mount brackets are different. completely different casting from the looks of it. Also A/C and alternator swapped places as well.
johnsonwillie199
