roof rack delete?
CbChevyLt_99
paulding
alright guys just doing some little nik naks right now to the truck trying to get a good clean look going. i just de badged her and working on getting the glue off im curious to ask how i can delete the roof rack. i figured just take it off and fill in the holes with shorter screws?? :hands: what are yalls recommendations and photos would be cool also if u have any detailed explainations that is
WhiteHoe.
i just took mine off. didnt put any screws back in or anything. doesnt look great. thinking about putting them back on until i get lowered..
BigDaddy13440
Rome, NY
I'm debating on doing a longer one from a Suburban, it'll make it easier to carry ladders on top. Either that, or I'll have someone fab up one from some 1" square tubing, make it full length - I can also add a few more crosspieces, and I could add some wire mesh to keep anything on top from scratching the roof.....
Brandon X
Michigan
What I did was just remove the rack and put in some clear silicone in the holes and then painted over the holes white to match.
the big blue bus
richmond, va
i was going to do that.. still got suburban roof rails i havent done it yet just put 4 cross rails on for now
tybardy
everyone needs a Hoe
Gilbert Arizona
I removed my roof rack, then filled the holes with stainless steel set screws and popped in a little silcone to keep things from rusting...
easy peasy!
CbChevyLt_99
CbChevyLt_99
paulding
alright see im thinking about having her painted in a few months and the guy i have body work done with said he could remove it and fill the holes in were they would crack or anything i noticed you guys said yall filled the holes with silicon and painted over them, well what happens when that silicon crack? dont it look bad?
strykerG8
how exactly do you take the roof rack off? do you have to get into the headliner or is it just screws in the rack?
retorq
Kingman AZ
Just screws down thru the top into the roof. There are 3 sets per side I believe.
bub
jersey
there are 5 screws per side. i started doing this yesterday to see what i was in for but put it back together. i gotta wait til it warms up a little more. i got stainless steel set screws and then will fill the holes with silicone. then to hide the female nutserts, i'm going to put black trim molding over them to match the ones on the roof.
the big blue bus
richmond, va
tahoe is 6 each side... 2 on the front 2 inder the rubber thing in the middle and 2 in back. hated when i took mine off to paint looked bad... suburbans look weird without em too jmo
Ski
Alabama
I tried 2 take mines off but the screws are 2 tight....
Big Red
New York
I removed my rack and put the screws back in the holes. Tightened them down as much as possible and then grinded them off and mixed a little body filler to smooth it out. ( Still in the process of this since it is too cold out now) Also removed the third brake light and flipped it to inside the truck.
njJohn
Aberdeen, MD
I got lucky. My rood rack was aftermarket. All it had was drill screw holes. I'm putting short flatter head screws with a dab of silicone sealer back in. Down the center of the roof was peel and stick moulding. That was long gone. Only some glue to deal with.
Big Red
New York
Yea I also removed the rub strips from the roof and have to finish removing the glue. Once it is warm out I will finish it and then put a fresh coat of paint. The clear coat on my trucks hood and roof was gone so I sanded it all down and painted my hood.
navi243
San Antonio, TX
Can we please see pictures of what you did with the third brake light
C Hoov
OK, not wanting to take my off, but the cross rails rattle bad. Anyone have any experience snugging these down? Don't know how they got so loose.
6point2lovelifers
