TPMS Reset - Failure
Mr. B
Rockford, IL
So, I was bored this weekend and tried to reset my TPMS system since the tires were rotated. BTW, I had them rotated at the dealer and they didn't do it, kind of pisses me off.
Anyway, the first tire went fine, then the second one would recognize to get the horn chirp. I didn't know what to do, so I kept going. When I got done, obviously it wasn't right. I tried to repeat the procedure, then it wouldn't even recognize the first tire and now I have a Service TPMS code. Nice.
Dealer, here I come.
iwaslowr
ɹǝqɯǝɯ ɹoıuǝs
Austin, Tx.
I would've expected the dealership to reset them too... perhaps one or some of the sensors are faulty?
zach2011
Platinum Member
Mine had the service TPMS message but it went away after a few minutes and allowed me to do the procedure again. Keep trying before you take it and good luck!
zach2011
Platinum Member
Turn the engine on to keep the battery charging.
Hold down the lock and unlock buttons on the key remote for 5 seconds, you'll hear the horn chirp twice and the DIC will say something about the procedure.
Go in this order and add/subtract air from the tire. The horn will chirp once to let you know when to stop letting air in/out.
  1. Front left
  2. Front right
  3. Rear right
  4. Rear left
After the rear left has been done, the horn will chirp twice, and you're done.
Mr. B
Mr. B
Rockford, IL
It's a different procedure for the Denali. It's in your owners manual. I'm under warranty, so i will fight them to do it for free.
They were all reading properly before the attempted reset, so I don't think I have a faulty sensor. But if I do, they need to replace it.
onebadrado
Waycross, GA
now this set up you have to add ar or take out to do it???? im wondering this because sometimes on my 26s the display reads all the pressure in all tires so the light dont come on and sometimes it dont and the light comes on... does this mean i have to reset mine..
freesat
  1. Front left
  2. Front right
  3. Rear right
  4. Rear left
Added 4 new tires/rims with new TPMS few weeks ago, but just got the "service TPMS message" showed last night.
Will try this procedure tonight... :)
k9lovr
Virginia
  1. Front left
  2. Front right
  3. Rear right
  4. Rear left
Worked like a champ... Thanks for the info
fire730
Louisiana
I thought I just had to push the button on the dash and when the DIC said " tire monitor active". I tried to do each tire with letting the air out and it didn't do anything. Why do they have that on the DIC if it doesn't do anything?
I definitely need to try it this way. Mine haven't displayed the correct position since I bought the truck over a year ago.
k9lovr
Virginia
On the first two tires I had to let out more air than the back two. It seemed like it was a lot but it wasn't. The back two beeped pretty quickly
djperryalexander
new orleans
tpsm
  1. Front left
  2. Front right
  3. Rear right
  4. Rear left
what!!!!!!!!! thanks man.. im doing this today.. i just got my wheels and hate to drive 20 miles to the dealer... i really dig this site.. startin to get hooked to this site :)
FLtahoe
Florida, USA
Dealer has screwed up mine twice after rotating tires....now i don't leave the shop until i know its right.
It sucks having the take out pressure (and then put it back in once you're done) for 3 tires....but when in rome.
For as much as the dealer cost - just get it right the first time.
fire730
Louisiana
Well.........Still didn't work for me.
It will not honk the horn to let me move past the DF tire. All my pressures display correctly and my left side tires are showing the correct position but my right side tires are swapped.
Hopefully getting new wheels soon so I guess I just need to make sure they are in the correct position when I put the wheels back on. And worry about it on the next rotation.
Any other suggestions? How about the handheld things that independent shops have to reset them? Would that work? I just dont want to pay to have it fixed.
fire730
Louisiana
They have always displayed the correct pressure but never the correct position.
I bought it used and it supposedly belonged to one of the mechanics at the dealership I bought it from. And it had the wrong positions when I bought it. And you would think he would have it set correctly since he worked there.
Houston, Tx
Here is a new question... I had the orginal 17s with the TPMS... its a 2005.. I have recently upgraded to the 20s LTZ Rims.. they also have the TPMS but now they dont measure the air pressure.. they guy that i got my tires from said i had to reset them.. I told him the way i did it before by the unlock and lock button and let the air out and he said there is another way since i changed rims.. i honestly dont think it matters with rim size but maybe i am missing something... the rims are from a 08 i believe..
Kcrowe79
