Two Incriminator audio 20.1 amps!!!
Dvldogyut
Item:
Incriminator Audio 20.1 amp
Specifications:
MSRP $1299
Power Ratings 1800 watts x 1 at 1 ohm
900 watts x 1 at 2 ohms
450 watts x 1 at 4 ohms
Strapable Pair 3600 watts x 1 at 2 ohms
Protection Circuit 4 Way (Overheat, Overload, Short Circuit, DC)
Frequency Response 10Hz~350Hz
Signal/Noise Ratio 105dB
T.H.D. @ 4 Ohm < 0.1%
Efficeincy @ 4 Ohm 86%
24 db Low Pass Filter 35Hz~250Hz
24 db Subsonic Filter 10Hz~60Hz
Size 7" Wide x 2.25" Height x 17.75" Long
Description/Condition:
Used*
cosmetic 9/10 few light scratches
Mechanical 10/10*
A couple of the speaker terminals are stripped and one is missing a screw. I have already talked to nick about fixing these. So they will all be fixed before you get the amp or amps.
Price:
$425 each plus shipping
Pictures (MANDATORY PICTURES WITH USER NAME & DATE):
---------- Post added at 10:39 PM ---------- Previous post was at 08:58 PM ----------
I would consider partial trade for some xspower d680 batts or maybe a d3100. And maybe some knu flex power cable*
D
Dvldogyut
I will entertain any resonable offers or trades.
Trades: xspower d680's or d3100's, knu wire 1/0. Maybe a good sq double din active capable.
stevek
Dallas, TX
Let me figure out if one will fit under my rear seat... doubtful but let me check and I'll get back to you
---------- Post added at 01:31 PM ---------- Previous post was at 01:30 PM ----------
When did you buy these? How'd you use them?
blueflamed03
Oklahoma
Steve, they are good amps, I personally know the owner of IA...stand up dude, matter of fact he emailed me wednesday and I forgot to respond....:(
stevek
Dallas, TX
Meh, I'm waiting to get paid back almost $800, need to start working on this $3000 job...
D
Dvldogyut
Both will fit under mine with ease.
I bought them about 6 months ago, I ran them strapped @ 1.5 ohms.
---------- Post added at 04:05 PM ---------- Previous post was at 04:00 PM ----------
The 20.1 amps have been proven time and time again to be bulletproof amps. You can run these all the way down to .25 ohms each. And run them on 18 volts. These things really like high voltage. They get even more efficient and make even more power then. They have been proven to do almost 4000 watts on 14 volts!!!
stevek
Dallas, TX
Well NBS vs NNBS. The space is a little more limited. I'm REALLY contemplating one, just need to get repaid
vsaravia
