Installing your LED Tails
tast101
Colton, CA
How to install your LED Tails.
We had a nice little thread on TF, and I figured I'd make a new one since the tails don't come with any instructions.
For this model, they have a clear version and a red version. Both come normal or smoked.
When you install your taillights, I would suggest numbering you light sockets and writing the corresponding # on the housing, just incase you need to install your old tail and to make things easier.
There are two metal clips that the screws catch on. These are located on your old taillights. You will pull these off, takes a little muscle and prying. But be careful, so you don’t break the plastic on your taillights.
When you hook up the harness' you want to follow the order above.
The Running lights/Brake light will be at the top.
The Blink will be in the middle.
The reverse light will be at the bottom and you will use the bulb for this.
If your lights aren't working check your fuses under the hood. I had a problem with my brake light switch, and it needed to be replaced.
(Don't remember his name off the top of my head, but on TF.com he had a little wiring diagram to have both the blinker and brake light to work in unison like the esky lights) Hopefully he'll join up and chime in.
Here's some pics of the non smoked version:
They can be purchased on ebay:
http://shop.ebay.com/items/_W0QQ_nkwZ2006Q20yukonQ20ledQ20taillightsQQ_armrsZ1QQ_fromZR40QQ_mdoZ
Found a vid:
[yt]zJ0grZP6zAg[/yt]
Feel free to add on other LED brands/models and if I forgot something add it.
SSmurdered
i know u see me
Pittsburgh, PA
im still throwing up the idea of just getting a set of led tails for my hoe which has barn doors. i have heard of peeps makin them fit and getting a certain pair that you dont need to mod to fit. anyone have led tails in there hoe/kon with barn doors RIGHT NOW. let me see some pix and how hard was it to mod if mods were needed?
tast101
tast101
Colton, CA
there's one of them that fits barn yard doors. I forget which one it is but I'm not sure about these.
Fyrcaptain
Richmond, VA
Are yours smoked....they look a little dark but not too bad. How's the daytime brightness?
I like the pic of the stock and new tails in place, shows the difference well.
Please explain how the esky tails blink.
Thanks
tast101
tast101
Colton, CA
Thanks
My are smoked, but they are purchased like that.
These are the regular ones:
These are the smoked ones:
There's no problem seeing them, from behind they look like this.
The LED light reflects in the housing.
Notice how only the top section is lit up. With the Eskys I believe the whole light lights up and blinks (both sections), With the LEDs only the middle section will blink while the top stay on constantly.
bwilly20
Carolinas (Orig.), Little Rock, AR (now)
guess i missed this thread on TF when i put mine on. it took me an hour to realize whi i couldn't get the screws to bite on the new lights. i was pissed. i created a thread on TF and everything askin for help, felt like a damn idiot.......
:emotions122:
tast101
tast101
Colton, CA
:emotions122:
Sorry I wasn't on TF as much as GMFS, if I woulda seen it I woulda help'd but yea the older thread did have those instructions.
danimalmax
louisiana
here are the tail lights i got, i love them, but they dont seem to be on ebay anymore
this is the mod i added afterwards to solve the loss of cruise control. i did this because its cooler than getting an equalizer or resistor, lol :secret:
Grocery Getter
A guy with a truck.
Phoenix, Az
yeah, what the hell are those, do they stop the rapid blinker?
danimalmax
louisiana
i didnt have the rapid blinker problem, i had loss of cruise control, it didnt work at all, so after a trip with the trailer hooked up, i saw how this could solve the problem, so i tied these into the trailer wiring that is right behind the bumper, plus u get red light that light up the ground when i turn my blinkers on or press the brakes
tast101
tast101
Colton, CA
how do you loose cruise control with leds?
I didn't loose my cruise control with mine. Only thing that happened to me right after I installed em, my brake switch went out (near the pedal), so that caused my brake lights not to light up and my cruise control not to work. So it may be something else not just the LEDS.
danimalmax
louisiana
its because of the leds using such low power that the car thinks its a burnt bulb, and reason tast101s were still working is because his probably has a resistor built in, mine didnt
and im not the first this has happened to, in fact if you go to autozone and look by the light bulbs, they have little resistor/equalizer packs to fix this if you have installed led bulbs in your tails, they specifically say its for rapid blinkers and cruise control problems
bwilly20
good to know, never heard that before.
SSmurdered
i know u see me
Pittsburgh, PA
:happy107:
tast101
tast101
Colton, CA
Nice to know, Mine are probably just like you said because there's a little box on the back side of mine.
jmildoc
Indianapolis,Area
yep that is true I dont have cruise control right now, i did install resistors on my blinkers to fix rapid blink but not the brake so my cruise doesnt work. and all i did was add LED bulbs to my tails and the front corner blinker
varminpoolteam
