I want a front bench seat.
derf0069
I have a 99 Tahoe and would like to replace the 2 front seats with a bench seat. Anyone done this? I haven't found anything yet. If you have what seats did you used and does it bolt right in? Thanks in advance. Also, could I put the 2 captains chairs in the rear instead of a 3rd row.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
that was a yukon setup just find yourself a 99 kon or hoe and transfer the parts I think you might need a little rewiring but otherwise the bench assy. should bolt right in.
D
derf0069
I dont care if it's power, as long i can move it manually. I just want to add the bench to the front. I guess I'll have to find a Yukon bench because I haven't been able to find one from a Tahoe.
---------- Post added at 10:25 PM ---------- Previous post was at 10:05 PM ----------
Or maybe a console seat/ Jump seat?
h0tr0d
Brenham, Tx.
Couldn't you just hit the junkyard and find one from the same year pickups and toss it in there. Seems to me it'd be a direct fit. As far as the captains go, you might be able to toss them in the very back and bolt them to the floor, if you anchor them correctly and fab up some seatbelts. Just remember that the cargo area doesn't have the same floorboard height as the front, so legroom is going to suck and you might even have to remove the headrests to clear the headliner.
nodark
Harlingen, TX
derf, where are you located?
I'm actually planning on doing just the opposite. I wanna swap in two captain's seats in lieu of my front bench
D
derf0069
Good point on the clearance in the back. As far as the truck seats from the same year goes. I'm all over it if they'll fit. That's what I'm trying to find out. If they do, I think my search for a bench will become much simpler.
Bad bow tie
Grizz Straight FTMFW
Michigan/NC
:signs16: i like my buckets too much
I enjoy my buckets as well. But to each their own.
You could find a bench seat out of an OBS Suburban or Silverado/Sierra as well. They came with benches too. My dads old Suburban 3/4 ton had a leather bench up front with a flip up console.
SunlitComet
OBS Jedi-Do Good
:welcome: Cholomike You wanted a larger picture on the front buckets correct?
Post some more info on your truck so I don't get the wrong picture please.
onlygm4me
Molalla, OR
Derf - How'd your project go?
I did the same thing on a '87 S10 Blazer, took the bench out of a '91 S10 PU and it bolted right in, even though the guy at the wrecking yard said it would never work.
swarren
Does anybody know if a 94 silverado split bench would fit in a 95 2 door tahoe?.
BigDaddy13440
Rome, NY
ANY seat will fit, as long as it's not wider than the original. Just take a few measurements, and fab some brackets to adapt the new seat to the old track.
I had a S-10 Blazer, I swapped in some buckets from a Grand Am.... sat about 2" lower (more headroom!) and they were MUCH more comfortable.
1996chevytahoe350
i have the 2 captain seats in front of my 96 chevy tahoe and i want to put the bench seat so i will have a middle seat up front, would a bench seat bolt right up? also does anyone have any pics if they done it
CKendrick
