DDM Hid
09Hoe
Chicago
Hi guys I've been trying to find other threads around here or maybe I just suck at searching but I want to know which kit should I order for the headlights with hi/lo? Thanks!
Modded
That Guy
Yeah you suck pretty bad at searching because that info is everywhere.
You didn't post what model/year you have, which is important.
blueflamed03
Oklahoma
great way to treat a new member..........:emotions122:
subtle hints
user name, and in 2007+ years gave it away for me ( hopefully )
09Hoe, assume it's for an 09 Tahoe?
blueflamed03
Oklahoma
if so, here are all the bulbs for your truck, see HI and LOW bulbds, that is what you'd order for the HID
2009 CHEVROLET Tahoe
Low beam headlamp
H11
H11SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility.
H11ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
H11XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
High beam headlamp
9005
9005SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility.
9005ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
9005EB EcoBright - Your Environmental Choice. Save Energy - Save Money. Up to 25% brighter light. CO2 reduced 9 to 21%. Gas savings $2 to $19.
9005XV XtraVision: The brighter light for upgraded performance. Up to 30% brighter light and up to 25% more downroad visibility.
9005CB Cool Blue: The whiter light for style. Up to 25% brighter light and up to 25% more downroad visibility.
Parking light
4157NA
Front turn signal
4157NA
Rear turn signal
3057
3057ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
3057LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Tail light
3057
Stop light
3057
High mount stop light
LED
Fog/Driving light
5202
9145
9145ST SilverStar: The brighter and whiter light. Up to 35% brighter, up to 30% more downroad visibility and up to 35% more sideroad visibility.
License plate
2825
2825LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Back up light
7441
Front sidemarker
194
194LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Rear sidemarker
194
Map light
212-2
212-2LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Dome light
212-2
Trunk/Cargo area
921
921ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
921LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
Daytime running light
3157
3157ST SilverStar: The brighter, whiter signal light. Up to 30% brighter light, up to 20% whiter light and up to 10% farther and wider.
3157LL SYLVANIA Long Life miniature bulbs perform twice as long as any standard miniature bulb. Designed for durability, lower maintenance and greater safety.
---------- Post added at 05:54 PM ---------- Previous post was at 05:52 PM ----------
added!
You may get by with just the H11, kit, I dont have them in my highs, but only low and fogs.
Good luck Henry!
09Hoe
Chicago
subtle hints
Yes it is sorry that I didn't post that lol:Plugged:
---------- Post added at 05:45 PM ---------- Previous post was at 05:44 PM ----------
Thanks for the help blueflamed! Great info.
---------- Post added at 05:49 PM ---------- Previous post was at 05:45 PM ----------
I'm still alil bit confused on how to order it on ddmtuning. I want to get Hids for the low and Hi what wattage should I pick and I should be ordering the H11 and 9005 for them right? and do I need the HID harness, Error Eliminator, and adapter cables? Thanks
UofMZ71
[/COLOR]I'm still alil bit confused on how to order it on ddmtuning. I want to get Hids for the low and Hi what wattage should I pick and I should be ordering the H11 and 9005 for them right? and do I need the HID harness, Error Eliminator, and adapter cables? Thanks
35 watts
h11 for lo
9005 for hi
5202 (i believe) for fogs
harness for hi and lo but not necessary for fog (if you want those)
blueflamed03
Oklahoma
But I would get the relay for the lows, less chances of any flickering or misfires :)
09Hoe
Chicago
Thanks! and sorry again for being a total nooooob is the relay the HID Harness or the error eliminator?
puckhead
CO
Hey, everyone starts out somewhere! Hope you stick around! Let us know how the install goes too
UofMZ71
yes its the hid harness, you dont need the error eliminator - unless you just want to buy it :hands:
B.G.
Im assuming the same goes for a 2008 hybrid tahoe? Someone in another thread told me h13 so I ordered and went to install today ane welll.......def not h13:emotions122: And if im reading this correctly, do I have to order two seperate kits?
One 9005 and one H11? I thought I read somewhere people were using High/low kits?
UofMZ71
hi/low (same bulb) are for cars that use one bulb for both hi beams and low beams. The yukon uses this setup but the tahoes have separate his and lows.
You will need the h11 for low and 9005 for hi (one kit each)
but to be honest i wouldnt get it for hi, unless you drive a lot on back roads or places you would turn on the his frequently...
zach2011
Platinum Member
Lows do more than well enough. But for me they come in handy when people aren't around at night.
yottybaby
