Vanity LED type/bulb size
felixgun
felixgun
Lafayette, LA
Vanity LED bulb type/size
Ordered these on superbrightleds.com and they were the WRONG ones!
High Power LED Festoon Bulbs
Festoon bulbs with 2, 3 or 6 High Power White LEDs Built-in Buck Driver allows wide operating voltage range
3022-xHP4
31 x 10mm festoon bulb with 4 High Power SMD LEDs
OklabyGodhoma
Normal....er, Norman, Oklahoma
My V-LEDS vanity lamps arrived today and they are installed. OMG, the light output is fantastic. At least I will now have one mod that the wife won't say was a waste of money. Honestly, I urge everyone to make this one cheap change. Thanks for the link to the correct lamps to use!
oakrdrs187
Coachella,CA
Why would Installed some myself and they are dim. I also put some in my girlfriend's galant and hers are super bright. Same LEDS, I put my meter on them and its at 9 volts, (why they are dim) anyone have any idea why?
OklabyGodhoma
Two ideas to check. First open and close the mirror cover several times amd see if the voltage changes and are you taking your voltage reading with the lamp installed? Second check the dimmer control on the dash and make sure it is full bright but without the interior lights manually turned on and take another reading....also take a voltage reading at another location in the vehicle just so you have a good base reading. Keep us informed.
felixgun
felixgun
Lafayette, LA
Ordered these....Thanks for posting,great product and fast shipping.Now where do i get the rest of the interior lights?lol
on ebay. search "Smd LED 212" and get 6 of them. 2 for front, 2 for 2nd row, 2 for cargo. make sure you get some from a US seller. good luck!
oakrdrs187
Coachella,CA
I did the reading with the bulbs off and the mirror door open. I also re-installed the stock ones and noticeably dimmer too. Dim switch is off.
General Fodder
