Interior L.E.D. bulb numbers for 2007 Tahoe
TahoeLuv
Las Vegas, NV
Hello,
I'm brand new to the site and I know that this topic has been covered already a few times but I'm a little confused still. I want to replace all interior lights with LED's but I want to make sure i'm buying the correct ones. For the Map & Dome bulbs (1st and 2nd row of truck) I believe I need the 42mm, 212 bulbs which I would need (4) bulbs total. On sylvania.com it gives the cateory of Trunk/Cargo area, now is this the 3rd row of lights, where the 3rd row seats are??? So are these a different bulb number? Or do I order 3 sets of the 212 bulb because all interior lights are the same??
Thank you very much for your help
zach2011
Platinum Member
All interior headliner bulbs are the same, so you will need six 212 bulbs, in size 42mm I believe.
Scotto2323
NJ
Search the forum, there are plenty of threads.
Dome - (6) 212 [42mm]
License Plate - (2) 194
Puddle Lamps - (2) 194
felixgun
Lafayette, LA
Does anyone know how to remove the plastic dome light cover in a tahoe? Trying to change out dome light and I can't get the cover off for some reason and I dont want to break it. Thanks for the help in advance guys.
zach2011
Platinum Member
You just pry it off with a flathead screwdriver.
OklabyGodhoma
Normal....er, Norman, Oklahoma
If you use a thin flat blade GENTLY pry on the long side of the lens starting about 1/2 inch from the corner. As you are prying don't torque hard or you can snap off the little "ears" that secure the lens. Installation is in reverse.....ENJOY.
felixgun
Lafayette, LA
Thin flat blade worked great! Got all six interior led lights installed with ease. Used the white 44m 212 festoon bulbs.
felixgun
Lafayette, LA
I just bought my interior/exterior led lights and one license plate led bulb went out and one of my interior dome lights is flickering. Anyone else having issues with there's? Bottom line: don't buy cheap led lights. Where do you guys recommend I get some?
OklabyGodhoma
Couple of things you need to do with the cheap or expensive ones. On the license and puddle lamps I found a little squirt of silicone spray and plugging and unplugging the lamps a few times cleaned the contacts which have a tendency to get a bit of light corrosion on them (pretty normal). Second on the dome lights before installing again a tiny squirt of silicone always helps and then squeeze the contacts together so when you install the lamps they are tight. Most of the american size of dome lamp is 44mm where most LED's are made at 42mm. That tiny difference can cause the flickering you are having.
Hope this helps.
felixgun
Lafayette, LA
The exterior license plate LED was the one that was flickering. Opened it up and found that half the LEDs burnt out (ONE WEEK OLD). Then I just opened up my front interior led's up-- One of them only had 2 out of 8 LED lights on (rest of them DEAD) and the other one had 4 out of 8 LED lights on. They SUCK. I already emailed both of the ebay sellers on how to proceed. I am posting both links below on which ones NOT to buy.
DO NOT BUY EITHER OF THESE:
Interior LED's:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=330479230612&viewitem=#ht_1388wt_1167
Exterior LED's
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=400148522349
OklabyGodhoma
Good that you have posted that heads-uo for everyone. Luckly neither of them was the supplier that I bought from. Keep us posted on how everything turns out.
Sorry for the bad news....that sucks.
felixgun
Lafayette, LA
After doing a little research, it turns out the more reliable and brighter/better lights are SMD-LED. ALL of the ones I ordered from those two links above are only LED (vs SMD-LED). I emailed both sellers telling them of the ones that burnt out and/or defective and they gave me partial refunds for the ones that were out. I told them I did not want them to send me a replacement as I was trying to find SMD LED's instead. The seller even agreed with me that SMD-LED's were the way to go! I ended up finding some more ebay sellers that sell the SMD LED's for both my 194 Exterior LED's and 212 interior LED's. They cost more but it is worth it.
waxworkz
link??
g35kid
So Cal
i got the 6 42mm 212 smd-led lights already....are you guys not changing the vanity mirror lights ur leaving them yellow?? which size lights would i need for those? this would be for a 2012 tahoe i want to make sure i cover all the lights in the interior i dont want any of those yellow lights thanks !!
NathanJax
Vacation Nathan
Jax, Fl
http://www.v-leds.com/Vanity-LED/c506140-1-2/
mine are 6k Left vs OEM right
CKendrick
