Calling all White and Black Hoe's!
Halldo
Post pictures of your white or black Tahoe with lists of mods/details! Who will be crowned Top Hoe?
Punisher66
Albany, NY
No Whites?
zach2011
Platinum Member
Very happy with mine, mod details in the sig.
Modded
That Guy
All these blacks only, segregation haha! Most of the customized Tahoes on here are black anyways.
UofMZ71
im having a sig made so ill post soon...
KMeloney
Black it is.
Halldo
Halldo
These are some pretty nice looking rides! But only one white? :p
BOSS
The People's A D M I N
Dallas
I've got a good one for ya...how about BOTH blacknwhite?
attachment.php
White Mods
Complete Custom Interior:
-Black Molded Full Carpet (Ultra-Plush pile)
-Black Mats (Lloyds plush)
-Black stitched headliner
-Black Leather seats w/Pearl White inserts from Katzkin (gathered, full leather option w/ "BOSS" stitched in front seat leanback)
-Black Perforated vinyl inserts (gathered) on small door panels front/rear
-Pearl White leather steering wheel wrap
-Entire interior semi-matte black
-HD hood
-Custom body color matched running boards (Lexus RX330 style)
-Clear Corners
-Pacesetter Armour-coated long-tubes
-Custom x-pipe with 2xFlowmaster 44 turned down 2.5 inches from exit
-K&N full CAI
-BB Tune
-Level III transmission build with all the kicks
-BB tuned every step of the way
-Dynamat'd hood, fenders, doors, firewall, engine compartment
-Underside of the body Dynamat'd firewall to rear end (even under tranny)
-McGaughys 3/5 drop (spindles, keys, springs, Belltech Street Perf shocks)
-DJM Shock relocators
-Rear spring isolators removed for @ 1/4in drop
-LED tails/3rd brake light
-24x10 U2-35s (old rivet style) with 305/35/24
-Dual weather stripping on A-pillars (windy where I live, cuts down wind noise significantly)
-Removed OnStar internals - installed dash cubby
-Pioneer AVH-4000DVD Double-DIN (custom dash fit by JKMotorsports)
-JL Audio VR650-CSi Components (Front Doors)
-Kenwood 6.5 3-Way (Rear Doors)
-Pioneer 10in Subs powered by 1k Pioneer amp (can't remember model right now lol)
-Viper 5901 Alarm SST 2-Way
- - Remote Start System
- - Audio Glass Break Sensor
- - Digital Tilt Motion Sensor
- - Mini-Piezo Siren
- - Invisibeam® Field Disturbance Sensor
- - Backup Battery System/Siren
- - Window Automation System
Black Mods
Exterior:
24x10 U2-35 wheels with 305/35/24 tires, SS front bumper cover, body colored grille and bowtie, Street Scene speed grille inserts, HD hood, Street Scene rollpan with flip-down liscense plate, Sir Micheals hidden hitch, debadged, removed radio ant and On-star cellular ant, tint-5% front/double 5% layer on rears, 6000k high and low beam HIDs, quad beam headlight mod, JDM clear/black projector headlight housings w/halos and turn signal housings, JDM clear/black tails, tinted 3rd brake.
Mechanical/performance:
6.0 LQ9 swap, Magnacharger Radix 112 intercooled supercharger w/2.85" pulley, dual heat exchangers for intercooler, Lingenfelter GT2-3 cam, Comp Cams LS6 valve springs, Pinned crank pulley, Pacesetter lt headers, true duals exiting through a pr of 40 series Flowmasters, BlackBear custom PCM tune, Hypertech 160* t-stat, S&B cai, NGK TR6 plugs, dual 16" electric cooling fans w/adj thermostat and custom shroud, tb coolant bypass, Performabuilt Pro-race series stage II 4L60E, Performabuilt 2500 stall converter, Fluidyne Extreme HD trans cooler, Eaton True Trac lsd, 4.56 gears,
3/5 suspension drop (McGuaghy's dropped spindles, Toxic Shock drop shocks, DJM 5" coils, removed rear bumpstop mounts and relocated bumpstops for additional axle clearance), KYB steering stabilizer, Energy Suspension bushings, SSBC big brake kit (larger rotors, calipers, and stainless steel lines).
Interior and Audio/video:
Pioneer Avic-D3 dd dvd/nav head unit, Pioneer BT-200 bluetooth interface, Ipod interface, Pioneer 910 XM sat/traffic tuner, Pioneer voice recog 6-disc changer (in cntr console), Pioneer CD-RB20 aux ip-bus input, Pioneer ND-BC2 back-up camera, Alpine V12 300w 4-ch amp, Rockford 1000BD mono amp with Punch EQ remote, two sets of Infinity Kappa 6.5" components custom mounted in front doors, Infinity 6.5"co-axials (rear doors), Alpine Type R 12" subs (2) in custom steel/mdf enclosure w/false floor. All Monster Cable ZN interconnects.
3000 watt Vector power inverter, two outlets in rear of truck, one outlet and remote switch on pass side of center console. Dual battery set-up w/PAC isolator, 1/0 ga cable with 200A ANL fuse and 4 way Maxifuse block, 1/0 ga. battery to chassis ground cables, 4 ga. alt to battery cable.
Directed dvd player (in cntr console), Directed 7" widescreen headrest monitors, 8" monitor in custom housing in front cntr console.
DEI Viper 5900 LCD paging remote start alarm system, up to 1 mile range. Integrated to heated seats and rear window and outside mirror defrosters. Window roll up/down, headlight activation, dual-stage motion, shock, and glass-break sensors, 15 sirens and horn-honk, 2 piezos under dash (no one's breaking in w/o attracting attention!).
Entire interior lined with 100 sq ft of Dynamat Extreme sound deadener and double layer of jute.
LED interior and puddle lights (super white). Blue LED gauges and HVAC control.
Autometer boost gauge in stock trans temp gauge location, Autometer electric full sweep fuel pressure gauge, AEM UEGO wideband AFR controller/gauge, dual a-pillar gauge pod.
RoHoe09
Houston
Typical mods everyone else has: wheels, exhaust, debadge, black bowties, iPod interface cable, interior LEDs, EGR bug/rock shield, etc...just your everyday Tahoe.
felixgun
Lafayette, LA
Wow you really went off huh? Escalade Tal lights, roof rack, bumper, trailer hitch cover, and all 2010 LTZ chrome pieces? Did you acquire all of these from different places?
I have an 2008 Tahoe LTZ and i'm looking for the 2010 LTZ chrome side moldings and the chrome strip on bumper.. then maybe the LED Tail lights and escalade roof rack after..
nick0923
Chandler, AZ
Here was my 07
But traded it in for this '10, pic is only a few days old with only 60 miles on it, got it while on R&R but have plans to black it all out once i get back to the states. Already removed that stupid pin stripe and limoed the windows. Any suggestions on some all black 24's?
zach2011
Platinum Member
I acquired my stuff from all different places, yeah. I got the roof rack and some interior pieces off my dad's totaled Yukon Denali, the tail lights are actually Eagle Eye G4's, chrome moldings came from Nordstrom's Auto, so they all did not come from one place! I think I replied to your thread with info on the moldings.
briannorris
