where to find lower airdam/valence from the 05-06 tahoes
hoe
Need to get the lower valance or airdam, that goes under the stock valence, the straight black peice at the very bottom. Where do I locate it, and whats the part number?
Mr.Martin
NC
Just call the parts department at your local Chevy dealer.
hoe
hoe
Got it, installed it with the 1 bolt on each end. The thing flew off when I hit 85mph on the interstate. Had to circle back around to get it, wasn't damaged though a car behind me ran over it, and it flew to the shoulder.
Now I need to put atleast 12 bolts and locking washes to it. I would hate to loose it, when I get up to higher speeds.
Dismay
Minneapolis
yeah, the airdams for the later models had extra tabs that would snap in all along the edge, when you try to install the valance onto an airdam of the earlier models you need to just drill some holes and use bolts washers to hold it together.
hoe
hoe
Yea, I drilled where each tab was, and used some zip ties. I hit 90mph today and it stayed together well, so I know I can exceed those speeds now. Has about 12 zip ties so that fiasco will not happen again. Had some the edge sort of grated up, but for some reason they both broke the same on both sides less than 1/4 inch. I have some pics Ill post soon.
---------- Post added at 03:08 PM ---------- Previous post was at 02:39 PM ----------
wwiizz
