How-to: Change the color of your 00-02 Tahoe/Yukon/Suburban gauges
ScottyBoy
Shreveport, La
Here are step by step instructions on how to change the color of the guages in your instrument cluster in any 99-02 GMT-800 truck or SUV. This is a very quick and easy mod, as no soldering is involved and it takes less than 30 minutes start to finish.This write-up only applies to 00-02 guage clusters. 2003-2006 have the bulbs soldered to the board and the cluster has to be completely disassembled to replace the bulbs.
Here is a list of all the supplies and tools you need to accomplish this:
6- size 194 or equivalent wedge base LED bulbs of your color choice.
Here are the bulbs I used:
250
6 - twist lock bulb bases for a 194 size bulb.They should look like this:
-a 7mm nutdriver or 7mm socket and ratchet with at least a 6 inch extension on it
-a flatheaded screwdriver or nylon pry/trim removal tool
First, remove the instrument cluster/radio dash bezel. This plastic trim will pop off with your bare hands, no tools are needed to remove it. You will need to move the gear shifter all the way to the right (preferrably with the engine off) to get the bezel offf of the dash. Now use your 7mm socket or nutdriver to unscrew the four 7mm screws holding the instrument cluster in the dash. Now lift out the cluster and unplug the harness from the top of it. Now you need to pry the back off of the cluster to get the bulbs out. Just use your screwdriver and work your way around the cluster release each of these tabs.
once you get the back cover off of the cluster it should look like this:
The 6 black bulb bases you see will actually be gray. (I took the picture after I replaced the bulbs) Simply remove your 6 stock gray bulbs and bases by twisting them a 1/4 turn and popping them out. Now replace them with your 194 LED bulbs with the twistlock bases. Here are my LED bulbs and twist lock bases compared to the stock bulbs:
Now put the back cover of the cluster back on, but don't pop all the tabs back on just yet. Go plug it in to your dash and test it out. Turn on the parking lights and see if all your LED's are lit up. If not, take out the ones that areant and flip them around. LED's are directional, so they will only work if installed with the polarity one way. Once you verify they are all functioning properly, re-install everything the reverse of removal.
Here are some before and after pics of mine.
Before:
After:
And here are some more after shots to show how they match the rest of my blue interior LED's that I did:
The write ups to the rest of my interior LED's can be found at the following links:
LED Power window switch mod
LED AC control panel mod
Tahoewhat
Ballin' on a Budget
TX
Apprecaite you taking the time on these writeups your doing. (even though mines different)
S
ScottyBoy
Shreveport, La
Just trying to share the knowledge. And I did post that 03 and up guage clusters are different and need to be soldered. Actually the soldering isnt the hard part, you have to take off the needles and its a severe pain to get them re-calibrated once you put the needles back on.
PUNKYOU007
Hopewell VA
Anyone have any troubles with these? I have had to get 4 leds replaced in the last 2 months. I got mine from Superbrightleds
denalianyone
NYBlackLade08
New York
Yea I had a few problems with some of the leds blinking and then eventually burning out. I put back in the factory ones and no problems ever since.
boostedgsxr1k
also are you using a single led bulb or does the bulb have nemerous leds in it? Because I have found single and 5 led bulbs
S
ScottyBoy
Shreveport, La
Depends on hiw bright you want the cluster. I have the ones with 5 SMT LEDs on them. You can get any 194 bulb you want, just don't get one that is too big or wide cuz then it won't fit into the cluster.
nachigh2010
What size are the twist lock bases that you used because I went to pick some up and the parrts store had multiple sizes.
S
ScottyBoy
Shreveport, La
I just got some for a 194 bulb. I ordered mine off Ebay. Advance auto parts had them, but wanted $3 a piece for them. I found a guy selling a set of 6 on ebay for 3 bucks shipped. They were from China and took forever to get here, but I was in no rush.
Tahoewhat
Ballin' on a Budget
TX
I am so about to do this, what is the cost to do everthing?
DO IT... I love mine. I had scottyboy do mine and im glad i did. I did all of mine though, cluster, switches everything...
Going to post up thread when i get the chance for some pics.
S
ScottyBoy
Shreveport, La
Yeah, the 00-02 cluster have replaceable bulbs that you can change yourself if you want to. Thats what this thread showzs you how to do. But the 03-06 Clusters have the bulbs soldered to the board inside the cluster. The cluster has to be disassembled to unsolder the factory bulbs and solder in some LEDs. If anyone wants one done, PM me and I can hok you up like I did Mike. :Handshake: I can convert any switch on a NBS 00-06 to LEDs if you want.
Tahoewhat
Ballin' on a Budget
TX
And if you would like pics, i do have some saved, just not the best right now, just pm me. Or look forward to my thread about them all. Looks killer at nite.
Z-56 Hoe
What do I do????
Houston
Mike wanna help me? oh and what am I looking at cost wise to do it all? A/C door and window controls too?
Tahoewhat
Ballin' on a Budget
TX
Pm scotty boy about it, since you live here, they will be to him next day. Should be, but hit me up and i'll show you mine. MUCH better than pictures..
Eickybobby5050
