Bilstein
Mike2012
Deleting z55 air crap as I’m having issues with it. Wanted to know what everyone is changing out to that deleted the air suspension? It seems a lot of guys are going with bilstein. 4600, 5100? What springs and top mounts are you using? Thanks
PG01
Up here to the right
5100’s imo
@SpareParts what ya think?
You will need to replace the rear springs with non-Z55 springs (from the same model year or generation, but with a non-Z55 trim level), as your current rear springs are softer, as the air shocks provided some of the support of the rear of the truck.
Folks here use both the 4600 and 5100 shocks, but I cannot comment on the difference. Other folks will chime in.
Mike2012
Mike2012
What I’ve researched too. Just not sure if I should go with standard slt springs or upgrade to something different. We camp a lot so light off-road and camping gear
SpareParts
North Idaho
No experance with the 5100s. I have used 4600s on a couple GMT400s and loved em.
Worked great for the light to moderate off roading i was doing and a nice ride on the street.
Marky Dissod
Never deleted air suspension, but for a cushy ride, 4600.
If you prefer a stiffer ride, especially if you plan on improving the handling or carrying more extra weight around than just your family, 5100.
... not sure if I should go with standard slt springs or upgrade to something different. We camp a lot so light off-road and camping gear.
If the 'upgrade' springs are stiffer than normal, 5100. If the GM OE SLT springs are one of GM OE's softer options, 4600.
Mike2012
Mike2012
But what would that upgrade spring be? if I go 4600, yes, oe gm slt spring. If I go 5100, what would that spring be. What have you guys used.same with rear, I could go oe slt in rear, but will carry loads for camping, so looking at that upgrade
LSCALADE
I went with 4600 and used some brand new cheap units off Rockauto to tear down and use as spare parts for the build. Turned out awesome. I do however have a new rear air compressor which works as it should so did not have to get the rear springs changed. They are easy to change if needed or you can use a spacer to compensate but to be honest the unloaded stock ride height does not change if the air system is disabled.
The ride is absolutely awesome soft and compliant and it slows down body movement greatly due to the monotube shock design. Worth it!
scottd
