[SOLVED] trailer plug not working
davidmeyer
hello, I'm new to this and not sure if this is the right place for this. I have a 2016 gmc yukon denali and I only have 12 volt aux and left turn signal/brake on the plug. Have checked voltage on all pins and disconected harness and have same issue at the harness. any suggestions. thanks
The underhood fusebox should have individual fuses for the trailer lights. Left turn/brake, right turn/brake, and running lights. The 12v AUX fuse is likely a larger J-Case fuse and you know that's working. Your owner's manual should have a diagram of the fusebox and the separate fuse positions.
Also verify that the ground connection is good in the 7-blade socket, because if that's not solid it may affect all of those circuits (and that can also depend on where you're getting your test ground).
D
davidmeyer
thanks i'll check
jkhuntzinger
