Rear spring spacers
Xafnyx
Hey everyone, I just did the 3/4 drop on my yukon denali. I was wondering if anyone knew of a company that makes a half inch rear spacer? I have the 1" one but I didnt like the look of the 1"
mikez71
I've not seen one.. 3/4" is the shortest one I could find (non metal)
I'm guessing the centering bump maybe 1/2", so maybe no way to do it.. ?
Maybe a custom bump extension that's bolted/welded in place, plus a 1/2" ring for spacer?
let us know if you find something..
X
Xafnyx
Yeah I saw the 3/4 and I think I saw another size shorter than 1". I'll definitely post back what I find
X
Xafnyx
Install heater hose around the bottom and top coils on the springs or install a spacer on top of the spring instead of the bottom.
Wouldn't installing the spacer on the top be the same as if you installed it on the bottom?
kbuskill
NE. FL.
It would still provide lift, if that is what you are asking.
The difference being the upper pocket wouldn't allow the spring and spacer to become dislodged.
LsHart
Senior Member
Okay so, 3/4 drop? What was used for the rear? Drop? springs? Did u chop stuff? Input..need input!!!
X
Xafnyx
I used the norcal belltech kit. So I believe drop struts and coils
X
Xafnyx
Oh. Was the advice about the heater hose and putting the isolator on top only to prevent dislodging? Or would it help give me slight lift?
LsHart
Senior Member
I'm always dropping, sorry my bad. And yeah, it will reduce the rear weight! As I clear my throat.
CRN_25
