Yukon Stopped While Driving
Slstorch
The history shows either the high Amp fuse (400 Amp) for the starter and/or the fuse block needs to be replaced when the engine cranking current gets too high. What many people do not realize is with the Push Button start engines, if the engine has an extended crank or will not crank, you can push the Push Start button to cancel the crank timer from the ECM.
I have seen a number of 6.2l engines that before they hard failed would shut off driving down the road. Then would often restart almost immediately or after sitting for a bit. Many of the locked up 6.2l engines would either require the replacement of the high Amp fuse and/or fuse block because the starter would be engaged in the engine that would not turn and the ECM crank timer is running for 5-10 seconds and the fuse blows/melts the fuse block.
I have even heard about a few cases where the fuse blows or the fuse block melts and needs to be replaced and within a short period of time the 6.2l engine seizes. So unfortunately is it not as far fetched of an idea that the engine may be on the way out and may already have signs of metal in the oil while it is still running.
I guess we will know if the OP ever reports back that the engine has failed in their vehicle.
My truck died on me yesterday. Shut off during a decel and got the restart engine message. Tried to restart it and it cranked over one time real slow and then stopped. It’s at the dealer now. The dealer just told me it needs a new fuse block. It sure sounds like I’m headed for engine failure. Other than making sure they tried to turn the engine over manually and making them check the oil for metal, what should I do? Can I make them measure cranking amps and see if the numbers within spec or something?This truck has 88,000 miles on it and is a 2022 so I am out of warranty. You also mentioned that history shows a failed fuse block could be heading for a failed 6.2 L. Do you remember seeing other threads on that in the forum? Or can you point me to where you’re getting that history? I’ll try to use it with the dealer.
jfoj
@Slstorch
This is a pretty classic case of the engine bearings starting to spin. Often the engine dies and when it cools off, if you can get it to crank again, it will restart and run for a while before rinse and repeat. This is either if the fuse block did not blow or if the fuse block was replaced.
The ONLY reason for the fuse block/Fuse to blow is high engine cranking current. Possibly could be a bad battery, but likely the engine is on the way out, especially since it died on you.
So the good/bad news is the mileage is rather high. BUT with the 6.2l Recall for 0W40 engine oil, you may be in luck. The problem is the only thing I have seen released so far is the dealer stop hold order on inventory either new, CPO or used. It clearly states on page 3 of the GM document, "regardless of age or mileage"!
But since this so new of a recall, not everyone will have their head around what the rules are. NHTSA has not even released their document last I looked.
Here is what I would do. Have the dealer to scan for any Pending OBDII codes, if you have a Pending P0016, this is a major red flag for engine failure from what the recall states. Have the dealer remove the oil filter only at this point and inspect for metal. They may need to cut the filter open, at this point someone at the shop should have an oil filter cutter and they should know what to look for.
If the filter is clean, then you are probably looking at maybe a battery issue. If the filter had metal in it, we know what the issue is. If the filter is clean, a new filter, $10, check the battery, make sure there is no Pending P0016 and cross your fingers!
If for any reason the dealer plans on draining the oil, have them get you about 4 oz in a clean container for an oil sample if you choose to send it in for analysis, typically around $40. If it was my truck, I would be interested to see what level of fuel dilution was in the current oil fill in the crankcase. If GM was to try an get out of any claims, if the oil was not significantly fuel diluted, this might help your claim, if the fuel dilution was high, I might keep this one to myself, but it could give you some insight about oil change intervals and why the engine may have failed.
I would expect based on the recall, you vehicle should fit the window and I would hope if the engine failed you would get a replacement engine, but this is somewhat virgin territory at this exact moment.
Good luck and report back.
Plimbob
Des Moines Iowa
Update - the dealer finally received the new trans and son picked it up on 5/15. As you would expect, GM did extend the warranty on the transmission.
Now the recall on the engine.... what a !@#$show.
JSchlagetter
so, this just happened to me. driving on a state route, lost power, got the press start button msg, nothing happened. had enough momentum to coast onto a side street. power is fine. ECM fuses aren't blown. every time i press the start button screens go black then come back up. stuck in P. towed 21 miles to the house (it's saturday so no service, will figure that out on Monday). From what I'm reading: a) blown 400 amp fuse, b) bearings, c) fuel pump control module. any other followups from those with similar experiences? 2023 denali ultimate I just made the 2nd monthly payment on. oh, and until now the Onstar app said there were no diagnostic issues/everything looks good. now it reads "engine and transmission system/schedule service now" warning light, along wiht ignition system/issue detected". 52,911 miles.
jfoj
Fuel pump module will allow crank, no start..
Blown 400 Amp fuse usually happens if engine is seized and you allow the start cycle and to try and start the engine rather than hitting the start button quickly If the engine doesn't appear to crank.
Sounds like the motor may have seized? Good luck! I hope it's not the case. But if the motor seized make sure you go on the NHTSA complaint website and document your situation so at least it'll be additional data for another failure.
Sorry about your experience.
JSchlagetter
yep, engine seized. dragged onto a flatbed and towed to the house, then dragged onto a flatbed and towed to a dealer, then bounced off the flatbed. hadn't needed to look at the "service" tab, Recalls and Warranties in my GMC app where it reads in pertinent part "L87 Engine Loss of Propulsion" (they don't say). so, it's a known defect in the 21-24 6.2L V8 engines. "The connecting rod and/or crankshaft engine components in these vehicles may have manufacturing defects that can lead to engine damage and engine failure." so, GMC is putting in a new engine and i have a courtesy rental until that happens (this is week 2). 52,911 miles so still have powertrain warranty. will definitely drive it around after it's fixed to make sure nothing is screwed up w/ the powertrain/front/rear wheels since they were locked in Park (Parking brake engaged). Payment #3 went in last week smh.
Nautilus571
Not sure if it is the same issue or not. 2023 Yukon XL with 3.0. Truck shutoff going 50mph switches to neutral will not restart till you can place in park. Dash says reduced acceleration, once in park vehicle can be restarted. Service Engine Soon light on. Dealer is saying fuel pressure control module, not sure I believe them
DEF system maybe? It does have triggers built in that will affect driving ability.
Rene123
2023 Yukon Denali Ultimate - Was driving home from work and it just stopped running. Had to coast to the side of the road. Aux power comes on; however it wont start, doesn't do anything and can't shift out of park. Being towed to the dealer. Anyone have this problem before or thoughts on what it might be?
That similar thing happened to me, it was the fuse bar on the battery.
Towmaster
