2022-2023 Denali issues?
optimusprime
I’m in the market for a Denali XL. I’ve heard there were several years of the new style Denalis tha had a TON of recalls. My budget allows for a 22-23 model. Are these years even worth looking at? What issues did/do these trucks have and what should I be concerned with if looking at them?
well, all generations have had there issue's
that being said I would do your homework and also go out and get in one or two or three or four and drive it and make sure it's suitable for you.
one thing that is not made crystal clear
if the engine will not start, then it cannot be shifted. it is locked in park and the electronic parking brake is set
there are tools that will work around that..... just, know that.
if it dies on the expressway, your stuck for sure, can't even roll it including just running out of gas.
not a deal breaker for many because those situations are rare, but just be informed.
also each generation has less and less viewable space from the drivers seat, the rear window view is about the size of a shoe box and the mirrors are smaller and all the plastic trim around the vehicle is more obtrusive. All due to federal safety rules.
but hey the jones next door will be jelly
ReaperHWK
I had a 2015 and the 2021+ models are light years ahead in regards to features, style, and comfort. Don't discount a 2022-2023 as you'll get a lot of features for the $.
However if I was getting those years I'd probably stick with the 5.3 as those are the recall years for the 6.2.
O
optimusprime
Are the 5.3’s in these years more reliable? (Ie less recalls)
Well that sounds awful! Maybe I’ll just look for a 2020 instead…
depending on the trim level of a k2 it could have push to start or keyed ignition or some also have those shifter buttons
if it is push to start with a shifter handle and dies at least you can pull the lower knee bolster and physically shift it to neutral if necessary. the linkage is on the steering shaft.
I think those push button shifters are the stupidest thing ever but if you know going in then it is what it is.
They have been around a while on other models so I guess there safe.
I just don't know if there samsonite gorilla safe... :shrug: if you know you know.
WalleyeMikeIII
Sunny and Snowy Minnesota
6.2L V8 in the Denali's in your target model year known to have issues (crank and rod bearings) that result in the need for a full engine replacement. There is a >120 page threads on this topic in Engine and Drivetrain section. GM recalled, did a remedy requiring 0W40 Oil,. Some of us, including your's truly, had their engine fail after the recall and remedy. NHTSA has an open investigation for both the original issue that led to the recall, and for those cases where the remedy was not effective. Both are still in progress. Powertrain warranty covers to 5yrs/60k miles, and any vehicle subject to the recall got "special coverage" on bottom end failures to 10 years of 150k miles, so as long as the rig is low in the miles range, you would be covered, the coverage goes w/ the vehicle, not the owner at time of recall.
Consider finding a 3.0 Duramax if you are set on a Denali, but they are much more rare.
Other than the engine mess, I have been relatively happy w/ my 2022.
dusttur
I have an 22 AT4 XL 6.2 (although they're not called "XL's" any longer). I have been extremely happy with the power, towing, smooth ride (magnetic suspension), space, etc. It does everything I need and does so with ease. The recall scared me but I took it in and it passed the test so now I have the 150,000 mile or ten year warranty which is good peace of mind. Drawbacks: windshield washer fluid pump failed outside of warranty and dealer wanted like $400 for pump and labor to replace. I bought one on Amazon for $20 and it took me 30 min to replace. 22 is the first year with fully digital gauge cluster if that matters to you (it did to me because I wanted to be able to customize the cluster). Manual calls for premium gas, so I use premium gas and it is getting quite expensive these days. Be careful with over the air updates; when we first got our vehicle my wife accepted the OTA that was being pushed out at the time while she was in an area with little to no cell service. Bricked the entire vehicle and it took the dealership about a week to figure it out. Just to get it to the dealership in that state (literally bricked the whole thing) was horrible, multiple towing companies wouldn't do it because we couldn't get it in neutral, had to stay in a public parking lot overnight unlocked because we couldn't even lock the doors.
Hiebs
Don't get anything with a 6.2.....unfortunately that's all that came in the Denali. I have a 22 on its second motor and the new one is having consumption issues, did it with 0w20 and now with 0w40.
KMeloney
Loving my '23 Denali. It's not perfect -- but no car I've ever had is/was.
00110100 00110010
I currently own a 2023 Yukon Denali XL with the 6.2 V8 motor in it. I bought it new and I am the first owner. It currently had 37,*** on it. GMC is currently in the process of purchasing the vehicle back from me. As I list the reasons below, please keep in mind that I love this vehicle and it breaks my heart having to sell it back to them to purchase something else. I do not like the headlights on the 2026 but that’s probably what we will be purchasing.
Issue number 1:
The first safety concern started a little over a year into ownership. Upon vehicle startup (whether it be manual start or remote start) the driver side mirror would not retain the driver memory position. It would go into whatever position it wanted to. Sometimes not even close to the programmed position. At this early stage, the frequency of it happening was not as high. I took it to GM and after a day they stated that they could not duplicate the issue and performed a SW update. The issue was fixed but only till I got home and started the car back up.
GM and I did this same cycle multiple times. Over the span of months and multiple dealership trips the frequency of the mirrors increased and it happened on every start up. Then the passenger side mirror started to have issues but the issue with that mirror is slightly different. I have that mirror programed to go down to the curb upon putting the car in reverse. The mirror would not always return back up after putting the vehicle into Drive. Which caused us to have to adjust the mirror back up prior to driving. That one also started with low frequency and now the frequency of the occurrence is higher.
The final straw with the mirror concerns was when the original mirror concern happened while I was trying to merge on the highway with my kids in the car. We were stopped at a red light and the auto stop/start function kicked in and shut the car off. When the light turned green, I took my foot off the brake, the car started back up and I drove on to an on-ramp. I was checking over my shoulder as I was picking up speed to merge, then when I look at the drivers side mirror to make sure I had enough space between myself and the vehicle on the highway the mirror was pointing all the way up and to the right so all I saw was my driver’s side tinted window. This raised a huge red flag for me because I adjusted them before I left the house which means the start/stop function caused them to move again. I then started contacting the main GM to get it fixed. They eventually sent an engineer which looked at the car and said there was nothing wrong.
Issue number 2
At 35,XXXX miles the car started squealing. I took it into the dealership for diagnosis and repair. Turns out that the cause of this was the bearings on the idler pulley were failing and was causing the belt to lean slightly. The pulley and belt were replaced under warranty. To me this is a little early for a car to start wearing this equipment.
Issue number 3
In December of last year, I was driving the kids to school when I felt the back of my head freezing cold. That was a concern because the car was remote started and I had the heater blasting to warm up the car before the kids got in there. I reached over my head to the top air vent and felt it freezing cold. I swapped them to the floor and it also felt cold. I asked my son how long has this been going on and he said all week. The rear vents finally heated up 20 minutes into the drive. I took it to the local GM dealership over Christmas break. (Issue numbers 2 & 3 were together). When I picked up the car the fixed issue 2 and said there there was no problem and issue 3 did not exist and the explanation provided by GMC—that this condition is “normal operation” per bulletin #PIT6373 (attached)—does not align with real-world use or basic consumer expectations.
First, vehicles equipped with dual-zone or rear climate control should not blow cold air onto rear passengers while stopped at traffic lights when the heater is set to the highest setting. That is not a reasonable or acceptable “normal condition.” Second, and more importantly, this issue is not limited to idling. It also occurs while driving. Even after remote starting the vehicle and allowing it to run for approximately 10 minutes, it can take anywhere from 15 to 25 minutes of driving before warm air begins to blow in the rear cabin. I always remote start the vehicle to let the cabin warm up or cool down before I drive anywhere. It usually runs on remote start for roughly 10 minutes.
The bulletin itself states that troubleshooting should include increasing engine RPM above 1,200. If rear heat improves, no repair is required; if it does not, normal SI diagnostics should be followed. The service writer and I performed this test together by raising the RPM above 1,200. The rear vents continued to blow cold air. I then switched places with the service writer so he could feel the airflow himself, and he acknowledged that it was an issue that needed to be addressed.
At that point, service writer informed his manager and requested that he come out to observe the issue firsthand. The manager refused to do so and instead printed the bulletin again, reiterating that the condition was normal.
Despite my explicit concern that I did not want my children exposed to cold air during their drive to school, the dealership retained the vehicle for several more days. When I was called to pick it up a week later, I was again told that there was no issue and that I would need to increase engine RPM to achieve rear heat. In practice, this would require shifting the vehicle into Park or Neutral at traffic lights, holding the engine above 1,200 RPM (which we already verified does not resolve the issue), then allowing RPMs to drop, shifting back into Drive, and proceeding—repeating this process at every stop. This is neither safe nor reasonable, causes unnecessary wear on the engine, and wastes fuel. It is not an acceptable workaround for a vehicle that is under warranty and marketed as family-friendly. Given the dealership’s refusal to properly diagnose the issue after failing their own prescribed troubleshooting steps, I took it to a different dealership.
That dealership said the same thing and I asked them to use one of the vehicles in their lots for reference. They kept the car another day. I then received a call the following day and they said that the vehicle in the lot warmed up within 5 minutes and mine did not warm up after 15 minutes of running. They took it back into the ship and noticed a little bit of coolant coming out of the weep holes on the water pump and that the coolant was low. They determined the water pump was failing. They replaced the water pump, belt, and topped off the coolant. Now it works fine without having to rev up the car. Before all of this, I heard some gurgling sounds coming from inside the vehicle, passenger side by the dashboard. I brought the car in for that issue and they again said it was normal but looking back at the issue there was probably air in the system.
Aside from those issues, there are a few things I did not like about the vehicle. Nothing major, it’s things we can all live with. When your fuel is low, it no longer shows your range left. It literally just says “LOW”. In order to see the range you have to go into the app. Also, “LOW” fuel disables remote star (Make sense as to why). The Bose sound system in the car is really good but to get the best of it you have to turn the Bose control on. Unfortunately, it is fully controlled by the speed of the vehicle. There is now low, med, or high. So, when you come to a stop lights it’s too low but then you pick up speed and it’s good. Vice versa, if you turn it up to where you can hear good while you’re stopped, then it’s really high at higher speeds. Another gripe is the automatic headlights. First, they removed the button and forced it through the turn signal lever. You have to find the sequence and to use the sequence you end up flashing other people before you can finally get it to activate. Second, you cannot use the fog lights with the automatic headlights. By turning on the fog lights the automatic headlights disable themselves. When parked on an inclined driveway, sometime when you shift into park or reverse there is a loud clunk and it can be felt through the vehicle. OEM Brakes wear out fast especially if you drive aggressively. Replacing them was easy but to get the brake light removed I had to take it to GMC and that cost me $200 because they wanted to verify that they were indeed replaced. There are a couple of other things, but I typed enough.
If you made it this far, please keep in mind that I do love this car. I think it’s GMC’s best looking Yukon & years as far as looks (In my personal opinion). So, I don’t say this to say badly about it because I truly do love it, but these are the issues I have had with mine.
Capital City
I've had my 22 for a few years and it is still going strong. Had the Pico test done a few months back and they said it was fine and added the 0W-40 oil and the 10 year warranty. I did change the oil when I first got it at 1500-2000 kms just because of the potential for foreign debris during the break in period. Messed up and did the second oil change myself with 5W-30 Mobil one and the third was the same. Dealer put the 0W-20 on the fourth oil change and now I am onto the 5th with the 0W-40 after the recall thing. A few recalls for towing programming and now there is a wheel lock up one I have to do in a month when I change over to summer tires again. The power steps tend to freeze up when its -30 so I leave them in the up or down position. They cycle when too much dirt gets in the hinge so that is annoying and I just lock them up or down until I can get to the car wash. The air bags on all four corners is cool but if you don't drive it then they leak down a bit but I had the dealer check it our and it's fine. Just drive it kinda regular and they stay inflated. No electronic issues. Installed a Roto-Fab Air intake because it looks cool. Gives it a bit more noise from the throttle but not sure if it helps at all. Cleans up under the hood though.
Overall I am happy with the rig. My first was a 2015 loaded XL Denali. This is the second. Can't beat the room for the kiddos and hockey gear and the road trips. As is mentioned further down the threads. Take a few out for a spin to get the feel of a good one or bad. If everything works it is usually a good sign. I am at 40 something K so it is pretty fresh.
dusttur
Issue number 1:
Issue number 2
Issue number 3
Mine also has the no heat in the back issue, but I live in NM so it's not that big of a deal. If it's cold I just turn the rear climate off and heat from the front. Not ideal but it works for the time being. Through the research I've done it seems the rear heater coil gets air in the line which doesn't allow it to function properly. I usually forget it doesn't work until the kids start complaining about the cold air. That's up next on my to do list.
00110100 00110010
Keep an eye on the coolant.
tjs3922
I had 2 - 2023 Yukon Denail's (his & hers). Stupidest move I made was trading them in. They were wonderful vehicles with zero and I mean zero problems on ours.
tooleyondeck
Northwest FL
Objectively, over 1 million of these engines have or will eventually grenade themselves so if you just absolutely have to have the 6.2 over the 5.3 then you are assuming the risk without mitigation.
1948Buickroadie
