GM Advanced 2-way Remote Start
zach2011
Platinum Member
Well, I finally bought a kit. It came in today, and obviously I can't install it because it requires a Tech-II programmer, but here are some pics of it compared to a normal key fob in case anybody was wondering:
Hope that helps.
zach2011
zach2011
Platinum Member
It's GM! It has 3 times the range of the regular remote, and does all the same things plus shows odometer readings, fuel level, tire pressure, and can change the radio station or song track. And 1 remote can do this for 2 vehicles, provided you install the other equipment in both vehicles. I think it's really neat, I got it for $100 shipped.
Calabrese
Shit man, that is neat, and it's not much more then the regular remotes. Never new they had something like that.
zach2011
zach2011
Platinum Member
The complete kit. It came with an antenna that's mounted on the 3rd row passenger-side window, and then a little black box that they install which receives the commands and communicates with the remote.
Modded
That Guy
Thats a good price for the part!
The install will run atleast $100+ though.
stevek
Dallas, TX
The antenna should go on the driver's side. The passenger side has the heated windows and the strips on the windows can interfere with the radio signal
zach2011
zach2011
Platinum Member
Oh. I thought I read somewhere it goes on the passenger side...must've read that about a different vehicle. But the wires you see on that window are not heaters, it is an antenna, I think for the FM radio.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
correct. ITs a antenna. Id jump on this but i dont have power liftgate so i need a different Pn
zach2011
zach2011
Platinum Member
Your part number would be 19156555 if you already have remote start.
zach2011
zach2011
Platinum Member
True. Can't wait to get it installed July 8th!
zach2011
zach2011
Platinum Member
Still haven't had a chance. :( I had to miss that appointment because my truck wasn't fully repaired. And I've been on vacation for 20 straight days. I'm getting it installed next week or so.
I read online that GM only allows their service department to charge for 1.4 hours or something similar, and I haven't seen anyone say that they paid over $150...though I don't doubt it happened.
sumo
rhode island
I got mine installed and been running it for a few weeks now. The Extended range alone is worth it.
jcrack_corn
mines been installed for about 6 weeks...80 bucks at dealership for the programming (i installed the module myself).
FYI...open liftgate...remove 1 screw near pneumatic lift arm on drivers side.
pop that piece of molding off (it wont come off, it will hang around the lift tube)....you may need to take the top trim piece off too that goes across the entire back.
look down and you will see the RCDLR module clipped into the body, with the two plugs facing down.....simply swap them out, the old antenna stays in the body, just leave the wire hanging....the new antenna mount wherever you want.
that will save you 1 hour of billed labor at the dealer (takes 10 minutes).
dont do it until day of install because your old remotes will no longer work.
Also, verify all functions on the advanced 2 way before leaving, make sure your liftgate and rear-glass both work, psi, radio, fuel, mileage.
the clock does NOT work (that is normal) on the remote.
The dealers dont have a lot of experience with these and usually leave something out of the programming or load the wrong software (like loading the rear glass, but not power liftgate option, etc).
by far the most useful feature is the remote start timer, and the range....its hot here and I usually remote start immediately after EXITING the car if i wont be long....lol
vsaravia
