2007-2014 Chevrolet Avalanche Yukon Suburban Cowl Panel Vent Grille Hood Hinge End Caps
Scrappycrow
Air Force
Alpharetta, Georgia
Do folks think there's a market for an aftermarket solution where you could replace just the rubber part? I'm thinking of fabricating replacements for my Tahoe and if there's enough demand at a worthwhile price point, I could look into a producible version.
89Suburban
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
My rubber lips were ripped off when i installed a set of ditch light brackets. I had to to make the clearance for them.
I ordered a set of these and installed. They are pretty decent.
the repops have been on the market for about 6-7 months now finally, figured it was just a matter of time
the soft rubber part is not easily replaced, not with anything would look right anyway, unless you bought some thick rubber and then used a dremel to thin out the edges and glue on from the bottom so it would fit right and still be attached firmly
MoundMedic7
