ReaperHWK
- Joined
- Oct 14, 2020
- Posts
- 992
- Reaction score
- 1,230
2015 Tahoe LTZ. Has vibrations when driving and almost feels to me like a misfire. Started about a month ago and is getting progressively more severe. Vibrations are not in the steering wheel feels like engine or drivetrain to me. So whatever is breaking is breaking more lol. The vibes seems to be at lower speeds around 40mph and go away at high speeds. Also when on part throttle the car vibes. Things checked/done:
1) tires were road force balanced about a year ago. I don’t see how these could be the problem. Rotated tires anyway to see if the vibes changed but stayed the same.
2) thought it could be something in front suspension. Checked all bushings they look good.
3) truck has all new magride shocks replaced about a year ago. Can’t see them being a problem.
4) went under truck and checked the rear driveshaft. Shock it all different ways seems to be good. No play.
5) noticed the front driveshaft turns in 2wd. Internet says it shouldn’t. Looks to be unrelated problem?
6) hooked up scanner and checked for misfires. Driving around I’ll get a few counts on cylinders 5,7,8. All other stay at zero. Not enough misfired to set a check engine.
7) car randomly throws a p0175 code. Bank2 rich. Replaced both pre-cat O2 sensors and the code still comes back every few days. Related?
Other things to note. The car had all new plugs in 2022. Also in 2022 I replaced all the passenger side fuel injectors(bank 2).
Anyone have any ideas? I’m just going to troubleshoot more on my own but if someone has a suggestion I’m all ears.
