Power steering fluid requirements
grouch
I'm fixing the really sloppy steering my on 1996 K2500HD. The pitman arm has so much slop the steering wheel turns 90 degrees before it does anything. I'm also replacing the idler arm as it is nearly as bad. Since I have to unhook the power steering lines anyway, I plan to put all new fluid into the system.
All I can find is to use "GM power steering fluid" or equivalent. What alternative can I use. If I have to buy GM fluid, I will. However, I've got some here already and don't want to spend money I don't need to. I have a new steering gear in the shop and a new idler arm and mount on order.
universal power steering fluid should be fine, it's mostly mineral oil anyway regardless of the brand
grouch
grouch
Unless they call for ATF, I usually use dedicated power steering fluid. ATF is really high detergent and the power steering fluid has better lubricating properties.
exp500
You mean Hydraulic fluid?
Funny what marketing can convince people is something else.
Towmaster
