15-20 Tahoe ride height sensor question
Platinumtier
Quick question on the 2015 Tahoe’s that came equipped with magneride and air ride. Are the back ride height sensors all the same from models that don’t have magneride? Are ride height sensors tied into the magneride also? I guess I’m trying to ask if I can fit the cheaper option
Believe you can right since air ride is only available with magneride ? And not air ride by itself. Or is that newer models only? Had got a blowout this morning on back pass tire and it broke rod to lever on sensor. Would pic below of sensor work fine? Thanks
P
Platinumtier
Was going to just replace connecting rod but I do see bracket that it connects to is a little bent
If it were me, I'd go to RockAuto.com or GMPartsDirect.com, enter your VIN, go to the Suspension section, and look for the correct part on the exploded diagram. It will be far cheaper than the dealer, and you will get the correct part that you need.
P
Platinumtier
Great idea thanks
Drewphil
