Service Stabilitrak
Jake707
Fairfield, CA
The wife’s 2017 Yukon XL Denali 6.2 had a service message come on saying “Service Stabilitrack” today. I checked it out with my cheopo scanner and pulled the two codes below but have no idea what they would relate to.
P182A
P0700
The symptoms I found while driving are below, not sure if they are all related or will help someone point me in the right direction but listing everything haha
- Check engine light on
- Service stabilitrack message at start up
- “Park assist off” message at start up
- Reverse camera does not come on
- Need to push the gas pedal much further to accelerate
- Clicking noise when releasing brake pedal. This one was odd but I tracked the clicking noise to be coming from the column shifter handle assembly. Only does it with the car in gear, not in park, and does it every time you release the brake pedal
- Turned the truck off and got a “shift to park” message even though the Yukon was in park
B-train
I believe the PO700 is a generic transmission code. The other code seems specific to the gear position identification for the TCM. It could be a failed sensor, harness, corrosion, internal switch, etc.
How many miles on the truck? Has the transmission been serviced regularly? Like every 40-50k? 8 speed trans I assume?
J
Jake707
Fairfield, CA
It has 170k miles and transmission was serviced a couple thousand miles ago, full flush, new fluid and filter. Yes 8 speed trans
L8T BURB
Kentucky
In my experience, depending on the failure mode happening at the time, the check engine light will often times prompt the stabilitrack light to come on.
Example, when my 2015 Suburban dropped a lifter and messed up the cam, I knew I was getting a new engine, so I drove it to the shop working on it. The check engine and stabilitrack light were both on. I would dig more into the check engine code, and my thought is that the stabilitrack fault will clear once the check engine fault clears.
J
Jake707
Fairfield, CA
I thought the shifter was worn out since it would move up and down while in gear so I replaced that with a new GM one but nothing changed. I guess that “sloppy” fit/action is just how they are. Instead of continuing to throw parts at it I dropped it off at the dealership to scan it deeper and they came back today with the below, among other things like brake fluid flush, coolant flush etc.
J
Jake707
Fairfield, CA
And of course the warranty company is saying this isn’t covered. Not sure why we bout that dam warranty package at this point haha
jaxscuby
Jacksonville, FL
P0182, which indicates a Fuel Temperature Sensor "A" Circuit Low. This code means the Powertrain Control Module (PCM) is receiving a signal from the fuel temperature sensor that is lower than expected, signaling a potential issue with the sensor or its wiring.
Myniguez
P182A
P0700
Hi there. Did you ever get this problem work out? My 07 Denali is having the exact same issues.
Myniguez
Sorry
Yes, ultimately ended up changing a wire harness inside the transmission and haven’t had the issue since.
would you happen to know what harness. I’ve been driving my Denali for months now with these symptoms and it’s driving me crazy trying to figure out what the problem is.
J
Jake707
Fairfield, CA
Sorry
It was called the Internal Mode Switch It was shorting out. Not sure if it’s the same for you but once that assembly was replaced the issues went away for us.
Myniguez
Thank you. I’ll look into. Appreciate your time.
CWool
