Another P2138 code please help
firstgenon24s
I am having an intermittent P2138 code, and I've been doing a lot of research here but I'm at a loss.
2007 Tahoe LTZ 5.3
I've replaced and have done the following:
Replaced TB - Acdelco
Replaced Pedal - Acdelco
Removed the fuse box and cleaned the connections there and applied grease
Replaced the connector at the pedal by disassembling the old connector and installing a new connector. I did not re pin the wires as they looked to be in good shape.
I can collect any data from the pedal that anyone needs, just let me know.
Sometimes it can be fine for weeks, sometimes it will throw the code and reduced engine right after putting it in gear.
F
firstgenon24s
Yes I can get that for you no problem. I also know there is a TSB but I am not sure what the Instrument Panel to harness connector looks like, or where it's located exactly.
OBSandaNNBS
Known Thread-jacker
@firstgenon24s Did you inspect the wires on the throttle body connector? That was my root cause of my issue. According to the dealership. It also grows my new pedal sensor, also according to the dealership. I would replace that with GM genuine, replacing as much wire as is practical.
The OP was last seen on March 11th.
1948Buickroadie
