Its not rocket science to A
look and read the recall in its entirety. B
to realize that just because the displacement is the same as an engine 20 years older that it isnt the same engine.
You know good and damn well I never claimed they were the same engine.
Is this the objective data you are advertising? Please…
There are numerous instances of bold and underlined references to the journal sizes being the same.
For the 900th time this is the salient point because this is where bearing design has to incorporate oil viscosity.
You never attempted a real response to this.
Instead you made up a claim I never made ( same engine) and then doubled down claiming what I posted proved your point about 0w20 when it did the exact opposite.
You can’t offer any technical response because you are out of your lane on this and are resorting to distraction and fabrication.
And yeah it isn’t rocket science to see that 0w40 can not only just work on a perfect manufactured crank but also ones with imperfect surface finish and dimensions.
This too is part of the recall no matter how much you ignore it and keep typing “ it isn’t the oil because
Millions of engines use it”
It is part of the recall because it is a countermeasure.
Gm isn’t going to put out a countermeasure in front of nhtsa that’s a troll job.
We gonna discuss houses some more?
Or what other lame distraction do you have?
