2015 rear shocks
Rdry1952
I have a 2015 Tahoe lt. the rear shocks are leaking air so I ordered some from Amazon. The ones I got have a wire coming from the top of the shock along with the air line fitting. The ones on my Tahoe don’t have the wire on top. Can I use them and just let the wire hang? I don’t know if I have magna ride or not. The Tahoe does have an air fitting on the shock.
Where can I find the rpo codes?
Welcome to the Forum from NH.
Pics of the truck, please.
Your RPO codes are located on a sticker on the inside of your glove box cover. Check for a Z** code to identify your suspension. Also, look for the secondary RPO codes related to your suspension 6** and 7**. With these 3 RPO codes, you can identify what shocks you need.
It sounds like you purchased shocks for a Magneride equipped vehicle (the electrical wire on the shock). No, you cannot use that shock in your truck if you do not have a Z95 RPO code, which it appears that you don't.
there will either be a rpo list in the glove box or scan the qr code around the drivers door frame area.
sounds like you just have rear auto leveling, so you "might" be able to use those
R
Rdry1952
Thanks for your help. I found the codes, Z85 looks like auto leveling.
Carfan
Welcome to the forum. Be sure to post pics of your '** when you get a chance.
justinakay79
