'05 Yukon Xl.... Replacing lower A arms,, but do uppers too?
mountie
Since finding my front bottom shock mount's rubber 'press-fit' attachment is worn, I ordered new lower A arms / w/ ball joints.
I just suggested the installer, about replacing the upper A arms / ball joints ,also, since his shop will be pulling everything apart anyway.
I figured, with 180,000 miles, .. this would be a good idea. Since, they are in there. ( The shop is a VERY good performance truck shop )...
So, A good idea, .. any suggestions??
mountie
mountie
If they're a VERY good performance shop, they'll give you very good answers.
Funny you should say that....... They did...... " Usually, it's the upper joints that wear out before the lower.
( The shop )....
When I replaced my control arms at 150k miles, I did both the uppers and lowers. To me, it just made good sense to do so.
mountie
mountie
Got all 4, A arms... upper/lower ball joints, and both tie rods ( they needed replacing)......
They cleaned the heck out of everything...... I go back in a few hundred miles for a re-torque.....
They re-wrapped wiring, as needed, with my Summit Racing - wire-loom, while they were digging around there....
You should have a better riding front end now, and you're good there for the next 100k miles.
Conedaddy
