Stole key fob - SOLVED
Jocko PDX
Portland OR
Someone stole one of my 2023 Yukon Denali key fobs. Is my only option to go to the dealer to have the other fob deactivated so that the stolen one won’t work either? Then I have to pay $500 for a new fob? Any suggestions appreciated
Pretty much but a locksmith is probably cheaper, the fob or fobs need to be reprogrammed in order to erase the old stolen one from the system.
AND, if it had the key inside the fob then they can gain entry through the door lock
Jocko PDX
Jocko PDX
Portland OR
so that means I would have to have the door and ignition re keyed as well?.
RST Dana
OH
Door yes, ignition only if it takes the key. Haven’t had a key ignition switch in years. Push button ignition for the win!
just the door, bu if it has some form of keyed ignition you would either now have 2 different keys or rekey it yes.
once the relearn is done all they could do is open the door
i thought all these new ones had push to start in which case if the fob was dead it is placed in a slot in the center console then it will start
GMT800 2005 Tahoe Z71
Navy Supporting Member
Just go ahead and fess up to your wife you lost it in a poker game. I am in Eugene and have heard about the "floating poker games" up in Portland.
Jocko PDX
Jocko PDX
Portland OR
So dealer quoted me $220 for the fob without the key or programming. It looks like these fobs are on line for a fraction of that cost. Has anyone ever bought a fob for a 2023 on line?
If you don't get at the dealer I recommend get at a locksmith.
you should be fine with buying one online, many should come with a key blank also or some may offer cutting the key as well, you might just need to provide the key code which the dealer can provide for you at the parts department counter. you just need to show proof of ownership and they can print it out for you.
just be sure the one you buy is oem and is the correct part number for your vin.
programming will still need to be done by the dealer or locksmith, locksmith should be cheaper.
Save yourself time and money, and go to your local locksmith. They sell fobs there, and they will program/re-program whatever is required to complete the setup. You'll be out of there in 15 minutes.
BeavOR
OK update here: I bought the fob on line at Amazon for $50 (dealership wanted $300+). I had it programmed at a local locksmith for $90 (dealership wanted $200). I am happy!
Assuming you’re in the Portland area, would you mind posting the locksmith you went to. Or DM me the name?
Thanks
Really glad that the locksmith worked out for you.
clogan2
I lost a fob to my '16 Tahoe LTZ. Bought a replacement on eBay for cheap, and programmed it myself using the procedure in the owner's manual. So, now my fob shows up as "driver #3", and the seat, pedal, steering and mirror presets don't recognize it.
Oh, well. I did save a bunch of money after all.
But it sure would be nice to have my pre-sets back again.
justinakay79
