Fluid Replacement - Good PM Practice or Waste of $$
Pops946
Houston, TX
Hey, all. Got my wife a ‘23 Tahoe Premier 5.3 about 2.5 yrs ago. Just turned 30k, mix of local & highway driving. Dealer recommends replacing all the fluids at this time - transmission, power steering, brake and coolant. Think this is good preventive maintenance or the dealer extracting cash?I’m to an age where I no longer want to do this sort of work myself. Think they want about $700 for this, cabin & engine air filters and new wipers. Filters & wipers I can still do ok. Thanks for any thoughts & experience.
2024 White Tahoe
Read the maintenance schedule in your vehicle’s owner’’s manual (or look it up online). I always follow the severe duty schedule.
Your dealer is trying to defraud you, as your vehicle has an electronic power steering rack (no power steering fluid).
WalleyeMikeIII
Sunny and Snowy Minnesota
According to the Owner's Manual Service Schedule for Severe use (which 90% of all personal vehicles fall into) (due tot the short tripping):
Brake Fluid: every 5 Years
Transfer Case Fluid every 45,000
Transmission Fluid every 45,000
Coolant: Every 5 years or 150,000 Miles whichever comes first
Power Steering: There isn't any...its electric
Air Conditioning Desiccant: Every 7 years
I would also recommend front and rear differential at 45k miles too, but that one isn't in the owners manual.
Net, he isn't wrong about what maintenance items will need attention (although recommending power steering fluid is a bit dubious, since it is electric) but the service interval he is recommending is a little early.
Pops946
Pops946
Houston, TX
Thanks. I’ll probably go ahead and replace the air filters. We’re in an area where the spring pollen drifts like snow. Wiper blades, too. But will hold off on fluids until severe service recommended interval. Didn’t find anything about brake fluid. Do y’all recommend replacing at some point, like when brake job is needed?
PPV_2018
Molon Labe
U.S.A.
I will just assume that you *thought* you heard the dealer say PS fluid, since as stated it does not exist for your model. But if they actually did suggest it, it would be the last time i set foot in that dealership.
As far as the original question: It is not necessary, but replacing fluids ahead of schedule yields no negative results.. but i mean 30k is a bit early. I would probably wait until at least 50k lol
Jay P Wy
Navy
Natrona County WY
As other have said follow the severe schedule and I would also add the differentials when the transmission/transfer case is done. The only one I don't agree with is brake fluid. Brake fluid is hygroscopic (absorbs water) so if you live in a humid climate 5 years may be too long.
jfoj
BMW and other manufacturers have typically recommended brake fluid changes every 1-2 years. As mentioned brake fluid is hygroscopic and absorbs water.
WalleyeMikeIII
Brake Fluid is in the Maintenance Schedule, see footnote 5 (pink oval around it)
jfoj
I would not let the brake fluid go 5 years, but at least they recommend flushing/replacing the brake fluid at 5 years.
Chances are most people will have brakes replaced in 5 years unless they barely drive the vehicle. So some brake maintenace may be performed assuming they just do not push the pistons back to put new pads on.
The other MAJOR thing you should consider is checking the brake bleeder screws and removing them and putting anti sieze compound on them. I have seem a lot of older GM brake bleeder screws that were made of crappy metal that both corroded away and also froze/rusted inside the brake caliper and either broke off or rounded off and could not be removed. I have no idea what the bleeder screws look like on these trucks and if there are any aftermarket stainless bleeder screws. Sometimes an aftermarket stainless bleeder screw is a wise investment.
Just something else to consider if you plan on keeping the vehicle and/or doing work yourself.
I think I missed the spark plug replacement on my 2005 6.0l, I think they have about 20 years and 275,000k miles on them!
2024 White Tahoe
Removing the brake caliper bleeder screws would require bleeding the brake system, including the ABS unit with a GM Tech-2, as air would be introduced into the system - and probably adding more brake fluid.
Putting anti seize compound on the caliper bleeder screws' threads would risk contaminating the brake fluid in the system.
jfoj
Anti seize would not risk contaiminating the brake fluid if done correctly with only adding on the threads and you would likely bleed/flush some fluid out of the system while doing this. Flushing fluid out can even be performed via gravity as well.
The ABS unit would not have issues as long as the master cylinder does not get low enough to introduce air into the system. Additional, the Tech-2 is not the only tool that can be used for ABS brake bleeding, there are plenty of 3rd party tools that offer ABS brake bleeding options. Additionally the majority of the time you can perform a full system brake bleeding, less ABS internal fluid flush, without a tool to activate the ABS system, as long as you limit the air in the upstream portion of the brake system. Even if you do get air in the upstream system, the majority of the ABS systems bleed off fluid in parallel to the brake system, so when inactive or not going through a self test they tend to not impact the primary fluid path to the brake calipers.
jerry455
The Tech 2 will not work on the 2021 and newer trucks. They are global B architecture. As someone who just had to replace a transmission in a 2021 Suburban that I bought less than a year ago with 70,000 miles on it, I say change the fluids. If you are keeping the vehicle, change them more often. It seems the newer trans fluids additive wear out sooner. I have always been taught to change fluids as preventive maintenance. Don't be so ******* the dealer. The HD trucks still use hydraulic power steering.
jfoj
@jerry455
Transmission failure was likely more due to a faulty valve body with worn valve bores and internal valve body leaks. ALL of the 10 speeds are possible subjects for these failures. I predict the 2023+ transmisison will have these same problems and probably be recalled for the TCM software update within the next 12-18 months.
Also agree that the "Lifetime" transmission fluids are BS. Understand that the fluid in the transmission will last exactly the lifetime of the transmission!!!
Denpending on how you use the vehicle the transmission fluid should probably be changed between 25k and 50k miles. If using vehicle for towing and/or hauling on a regular basis, recommend 25k mile fluid change intervals.
SuperOldSchool
I do brake flushes every 1-2 years.
Trans fluid should be every 30k with the 6,8,10 speeds (my opinion).
See my changes fluid below:
RogerK
Just changing my transmission fluid was more than that.
jfoj
I’d contend most grocery getter uses of this vehicle constitute severe; as short trips on the 6.2 don’t get the oil up to temp.
Logged the oil temp recently when the ambient temps we 80F and it still took approximatly 20 minutes of driving for the oil to come up to temperature! Larger oil capacity has some benefits, but also has some drawbacks.
viven44
Dallas, TX
Maybe a different perspective from someone who has resuscitated many barn finds.... its quite amazing how the different systems work after all these years and what does/doesn't survive the ravages of time. Engine oil is obviously bad, when I remove the drain plug there is a lot of condensation that pours out first, coolant is surprisingly usually good, as long as a good mix was left in there, transmission fluid is always good even after an extended period especially considering the old systems were "open", brake fluid is garbage usually and takes out all the stuff with it (seals in master, calipers, wheel cylinders)...
A job not done is better that a job half done, if you plan to keep your vehicle for about 15 - 20 years, stick to the normal use case service intervals and you will help yourself dearly (and then discretion by testing on top of that on most things!) unless you are driving in a lot of dirt roads, extended idling in hot weather, towing, and hauling which is the classical definition of severe use.......
You are more likely to mess up something by getting stuff messed with by a “code reader” as I saw being described in a post yesterday. Maybe brake fluid because it’s a safety item, but even that not at the severe interval.
About the claim of severe use, I’d like to understand how short tripping can and affect anything except engine oil. Everything else is a closed system, and moisture is usually the aggressor in an open system. I can possibly see transmission fluid, but even that is closed unit these days.
Coolant is relatively easy to replace, but you can also test it before needing replacement just a simple multimeter for electrolysis, and also you can check mix with a cheap $5 hygrometer.
jkhuntzinger
