2013 PPV High Beams not working.
TexGiant
Hello - I have a ‘13 Tahoe PPV. I replaced the headlight assemblies and all of the bulbs. The high beams are not working. I don’t know if they worked prior to my installing the new assemblies and bulbs or not. Any thoughts?
opfor2
Riverside County, CA
I’m sure that they had wigwags installed and removed the module but did not splice the wires back. Trace the wires from the lights back to the right side of the radiator and see if you find any cut wires
T
TexGiant
Do you have any idea on the FRONT strut/spring assemblies? Some posts state “same as all other Tahoes,” but some manufacturers exclude PPV on fitment specs.I just bought rear Gabriel 43181 “towing” Shocks with springs along the sides, to hopefully raise it some. (Looking to tow a 3,500lb RV), but can’t find any options for front strut spring combo. I’ve searched the threads, but all of that information is old and the part numbers are outdated. I’ve called and searched the web and found one $500 option but that’s ridiculous. Just want a standard or even softer ride. Waiting to find parts… already bought tie rod kit control arms. (Have to pay mechanic because I can’t physically do this on my own.) Thanks for your help!
MonteJ
