ALLENY66
- Joined
- Jan 28, 2025
- Posts
- 3
- Reaction score
- 0
i have a 2024 tahoe z71 when pulling a tandem 16ft trailer with a sub compact tractor on it running 70 miles a hour got 10.5 miles to gallon does this sound normal?
Yesi have a 2024 tahoe z71 when pulling a tandem 16ft trailer with a sub compact tractor on it running 70 miles a hour got 10.5 miles to gallon does this sound normal?
It’s not so much the weight, it’s the drag.1500 lbs
ok thanks just figured with the 10 speed transmission it would be betterIt’s not so much the weight, it’s the drag.
Sub compact trailers are not aerodynamic and if your utility trailer has a dropdown ramp that rides vertically, you’re basically pulling a sail.
I go from 18-20 mpg in my truck to 8-10 as soon as I hook up my 16ft utility trailer, no matter what the weight is.
Once you figure out how to make it less like pulling a parachute, fuel consumption will improve.ok thanks just figured with the 10 speed transmission it would be better
Yep, I pull a 7x18 Inline Snowmobile trailer and I about 8.5-9 mpg with the cruise set at 72 mph on the highway. I have the 6.2l engine.i have a 2024 tahoe z71 when pulling a tandem 16ft trailer with a sub compact tractor on it running 70 miles a hour got 10.5 miles to gallon does this sound normal?
I pull a 4300lb sea ray V hull behind my 2006 XL Denali with a 6.0 and I see about the same mileage. But dang you guys hit some serious speed when towing lol. I keep it 65 or below……. But then again the southern California freeways are kinda a nightmare when towing lol.I believe aerodynamics are indeed key.
I tow a 4500lb boat regularly and get 13-14 MPH at 70 MPH while doing it.
