Radio install options
justsethpc
So I want to install an aftermarket radio in my 2011 PPV. Do I HAVE to use those expensive harnesses or can I literally just connect it and go? I don't have onstar, or steering wheel controls, or rear video.
IMO, you are always better off purchasing the pre-made connecting harness. It is small money paid to avoid making a mistake or having a 'cold' connection joint. We've seen more than a few folks come to this Forum, after making their own splices and not getting the intended results.
Now, if you don't have any steering wheel controls, then you don't need to purchase the interconnection module (the expensive one), just purchase the pre-made interconnection connector pigtail adapter.
Plus, if you ever want to unload the truck, it is an easy swap to re-install the original radio.
J
justsethpc
I should have specified. I was looking for a pre-made harness but didn't know if I needed the pricey one.
what exactly is "pricey" in your book? $20 $100?
you can go to walmart and grab a acceptable one for like $40 and wire it up yourself and retain rap and chimes
Really? All I'm finding is $100+
for a ppv? you don't need bose, onstar, rse yada yada
a basic adapter that retains rap, chimes is all you need.
maybe a separate steering wheel button adapter if you have buttons
all you need for a basic radio is the axxess AXDI-GLMLN29 and a trim kit which you can usually find for like $20 or so
it's $49 at walmart and $44 at sonic electronix
Fubar0715
Scott
Southern New Hampshire
Hey - thought I would share my experience. I have a SSV (4x4 version) that lacked any "extra" entertainment options so I did some research. I ended up with a new HU, 5ch Amp, 4 door skrs, sub, sat radio, and back-up cam. Don't need all that stuff, you can get a new HU with everything to install (if you have some skills) for sub $200 - here is an example.
My HU is same brand but higher end - above includes everything to install with model numbers. Dont need Android or CarPlay - you can find a less feature filled HU for sub $100. The screenshot is from Crutchfield. Good Luck!
J
justsethpc
Hey - thought I would share my experience. I have a SSV (4x4 version) that lacked any "extra" entertainment options so I did some research. I ended up with a new HU, 5ch Amp, 4 door skrs, sub, sat radio, and back-up cam. Don't need all that stuff, you can get a new HU with everything to install (if you have some skills) for sub $200 - here is an example. View attachment 444713
Yeah I already have a $500+ head unit i had in my previous car luckily lol
Fubar0715
Scott
then your kinda stuck with not getting a discount for the HU and harness-sadly. I had forgotten how pricey those things are without the discount. @Doubeleive probably showed the best price at Sonic Electronix (do recommend them)
RichardCranium
Mebane, North Carolina
Here is the kit I used.
If that doesn't work, search Amazon for UPC 712691534220
Comes with everything you need. If you remove the factory radio, you aren't going to have door chimes or any of that jazz, part of the reason this is a bit more than just an install kit. The benefit of that, you can increase those volumes or even decrease them, if you want. You still get steering wheel control and everything as well. And for the record, you can buy a new or used steering wheel with radio controls, and it will literally plug and play with your PPV. My steering wheel felt like I was squeezing a bag of warm ******, NC State Highway Patrol wore than thing OUT. I got a brand new leather replacement, felt proper and no longer like a turd-toucher. Highly recommend! And I don't have to put by beer down to cut up the radio volume or skip tracks now.
RichardCranium
BTW, I logged all of that into my build thread. This link will take you to my head unit install, I also eventually added a sub amp and a single 10", the Alpine amp that mounts behind this head unit, all new door speakers, and Motorola MA1 wireless AndroidAuto adapter. Its all in the thread if you are curious.
that's a pricey little bastard for not even having chimes
mikez71
I like no chimes! Try it awhile, you might like it..
Don't miss the turn signal sounds anymore either..
mikez71
True, although I remember there have been a couple times I forgot, even with the blinker sound and the mirror turn signals...
I probably forgot it a couple times more, without.. (but still glad I got rid of chimes and mirror signals)
waveryd
IL
Crutchfield has a great table that shows which of the aftermarket harnesses/adapters you need for the various functions to operate. It will not specify for PPV but does show functions.
JamesinAbilene
