Projector headlights... Any regrets?
slow_hoe_pro
Portland Oregon
I am considering buying my first set of projector headlights for better visibility. Does anyone have any regrets?
adventurenali92
Big Bear Lake, ca
My regret is not doing a true HID RETROFIT with the first set of headlights I swapped in. I went with similar halo ring housings for my Denali. Most of these aftermarket housings have cheap plastic projector lenses that aren’t any better quality than the OEM projectors, a lot of them have H1 style bulbs built into the housing that you can’t change, such as the ones I first went with. and the ones that have 9005 or H11 style bulbs, most guys will throw cheap LED bulbs in them that just scatter the light band terribly and don’t work effectively. If you’re trying to go LED low and high beam bulbs you will need a projector lens designed to take an LED. Some of the housings now come pre built with better projectors that run LED or HID but they’re pricey and for the price I think it’s still better to do a projector retrofit.
tooleyondeck
Northwest FL
I am also in the market for aftermarket projectors as my current aftermarket headlights are beginning to crack and yellow (DNA Motoring). They lasted about 3 years and for the $128 I paid for them I think that's acceptable, so no regrets but I don't think I will go with the same model again. Currently looking at the AKKON and Spec Ds but like Chase mentioned, you need to look into them because you may be getting crappy "fauxjectors". I'd take a stab at a retrofit if I hadn't disposed of my factory headlights, live and learn I suppose.
those look like some I tried once, they did not work very well AT ALL
in my opinion you are better off going with a stock style CLEAR housing and HID's the output is fantastic especially if you add some good fog's
and aim everything properly.
adventurenali92
Big Bear Lake, ca
I retrofitted a set of anzo U bar housings since they run identical to OEM projectors and I was surprised at how easy the retrofit was. But all in I spent a lot on that mod haha.
SpareParts
North Idaho
Get THESE Without a doubt the best set of lights i ever had for that style of truck.
They also looked fantastic once installed.
dps01
Senior Member
Navy Supporting Member
N. TEXAS
Installed the version of those w/o the integrated DRL and kept existing lower lenses w/LED bulbs for DRL, turn signals and parking lights… keeps the looks more stock(ish) but with integrated LED headlights (vs bulbs) & the ability to have the 4 HI mod done @ the headlight.
Jimmyy
Minnesota
I have a 06 Denali with after market Oem style lights. I could hardly see the road without the fog lights on. Installed some cheaper Led blubs and what a difference. The newer Led blubs are made so the light output is in the same location as the halogen blubs. My cut off is the same as before but with a brighter light. I don’t get on coming traffic flashing me.
adventurenali92
Big Bear Lake, ca
Looks decent!
mountie
Absorbing all these replys....... So, upgrading to an HID w/ new OEM housings ( might as well).... is the best?
NOT projectors .... ( I prefer a stock look )
I got fog / Morimoto HIDs.... haven't installed them yet ... Are Morimoto HID headlights the best?
( '05 Yukon )
adventurenali92
Big Bear Lake, ca
( '05 Yukon )
This is not the best solution if you’re not running a projector lens housing. HID bulbs are designed to scatter light properly with the right cutoffs in a projector lens. So when they’re in a standard reflector lens they’re not going to function right.
I run Morimoto HIDs and have had good experience with them. My retrofit kit came with cheap knock off Chinese branded HIDs. I ended up ordering Morimoto HIDs about a year after the swap. One did burn out prematurely, but I emailed them and they honored the warranty on it and shipped me a replacement and got it to me fairly quickly. Thankfully I had the original knock off HIDs that came in my retrofit kit so I ran those while I waited on the replacement.
dps01
Senior Member
N. TEXAS
Update:
Minor issue in getting the L-shaped retaining pins in correctly. Required a bit of wiggling / finessing of the headlight module to get the pins to slide back in vs. the OEM assembly.
After adjusting the headlights properly I am extremely satisfied. Excellent light cut off on drivers side.
It remains to be seen regarding longevity of the units, but happy with the upgrade @ this time.
scottd
