07 LT 5.3L Sudden no start/crank
rockola1971
Indiana (formerly IL)
So I went back again this morning and did some continuity tests from the top of the board, starter relay terminals, to the bottom of the board terminals that plug into the banks of wires that run to the other components. Relay terminal 87 (F1)(to 40amp starter fuse) has continuity and is good. Relay terminal 86 (C5)(to ECM starter relay) has continuity and is good. Relay terminal 30 (A)(hot at all times/main power) has continuity and 12v and is good). Relay terminal 85 (N5)(ground to engine block) has no continuity to the N5 terminal on the back of the board. I ohm tested the wire it plugs into under the fuse box on the vehicle, and it tested good for a ground. Since the computer is sending the crank signal, it's reading the key in the crank position, no theft control module is active, the starter jumped off the relay and worked, my only thought that it can be is the ground (N5) on the board. Without the ground it won't activate the relay. And I wasn't getting any clicking in the relay when we were trying to crank it yesterday. I'm attaching more pics of the "bubble". By the way, I also checked the N5 (ground) circuit which also leads to the ground terminal on the "run/crank" relay and I had continuity there so it does seem like there is a broken connection between the N5 plug on the bottom and the ground (85) terminal for the starter relay.
Your middle pic shows a trace that has acted like a fuse because the current passing through it exceeded its rating. So that trace heated up excessively and melted just like a fuse element does. You can lightly scrape the green color off of the trace on both good sides of the fused trace and install a jumper there by soldering a wire across the gap.
Now for 2 of the most likely causes to this trace failure. One is a poor connection at the stabs for the relay. This can be easily inspected to verify with a meter and visually. The other cause could be that the coil in your relay has partially shorted (not to be confused with short to ground). I would compare resistance measurements of your old coil in the relay and a new one. If you see the that old one has a coil resistance that is substantially lower than your new relay coil then you found the culprit. A coil is just that, a coil of wire that when energized puts out a magnetic field. A coil can fail in one of 2 ways. It can burn in half like a fuse and become open or it can have some, many, all of its wire coil windings melt together which overall lowers its resistance.
When a coil melts together and its resistance halves then the current feeding that coil doubles. Which means the traces in your circuit board for that coil (12v and ground) have to deal with double the amount of current that they usually handle and that amount usually exceeds its rating. As an example a coil that has 6ohm value into 12v yields 2a in current or 24w of power. If that same coil melts in half then it is now 3ohms and that value into 12v yields 4a in current (See...it doubled) and the power would be 48w. Power doubled also!
It is not a bad idea to replace relays in your vehicle every 5-7yrs. Maybe even more often in really hot climates like a desert state. They are cheap and this will avoid problems like this.
rockola1971
Since the starter relay and the run/crank relay share the same N5 ground on the bottom of the board and the run/crank N5 seems to have continuity and the starter doesn't, I added a jumper wire. I'm going to see if it works. If so, this will be my permanent fix. This jumper is just a ground wire.
I would reposition the wire on the top right where it is up against that stab so it doesnt rub through the insulation later on down the road. Add a couple dabs of silicone gasket maker or even caulking to the wire to glue it down on the board and in place. That wire is plenty large enough for the normal current levels it will be seeing.
j91z28d1
should just be a few mA of current to close the relay contacts. the starter solenoid is grounded thru the block. the wire will be fine as long as it doesn't short something else out from rubbing on a positive tab. but I doubt that bubble is from a trace burning out. they always discolor the board if a short burns one up. more like it cracked from flexing or a bad solder joint somewhere.
gm has a history of circuit board failures. usually solder points break. not from bad factory solder but from moving around over time. I'm guessing lack of support designed into it. tons of cases where you take the module apart, reflow the solder and put it back together and alls good. from obs abs modules, to c5 corvette abs modules, even Gen 2 volt hybrid battery control modules. gm has a very long list of using badly designed circuit boards that fail over time.
I feel like this fix it fine. yeah, can't hurt to grab one at a junk yard if it's cheap and easy swap, but I don't know that if I'd go thru the hassle myself unless something else fails on it.
J-Herkel
J-Herkel
Great information! Thank you!
J-Herkel
J-Herkel
Yeah I definitely am not going to go out of my way right now to fix it if it breaks. However, if I happen to find myself at a junk yard in the future, i will look for one to have on hand.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I definitely considered setting it a blaze a time or 2.. but I also needed to get to work so had to keep at it! Appreciate it!
I felt the same way a few years ago when my throttle body harness took a schit. After several weeks of agony I finally found a hack job splice job at the pigtail under the wire loom that failed. Really proud of myself and the members here that kept me going. Great forum and members.
J-Herkel
J-Herkel
Well, anyone still following this thread?? If so, quick update. Ended up having to replace the starter after all last weekend. Went to start it and again, nothing. Everything was getting power as it should, grounds were all good, so I took a long ratchet extension amd a hammer and beat on the starter. She fired right up. Replaced it that day. Worked great for a while. Later that evening, did it again. Went to start and nothing. So now I know my relay is getting good ground, my starter is good, everything else is good. The problem is a loose connection somewhere in my fuse box. I'm not sure if it's under where the box plugs in, if it's on the board or a terminal in the box. Anytime it does it, I have to pop the hood, wiggle the fuse box latches slowly until i hear the fuel kick on and everything in the engine bay come to life, then try and start it. Usually after a few times, I can get it. Whenever it does it, it throws a "service air bag" message and throws the Theft deterent dummy light, but once I get the connection right, it all goes away and it starts. Seems to me like it's either a loose wire or terminal. Where within the fuse box area, I have no clue. But for now, at least I know the problem and can get it started within a few minutes if needed. Just wanted to update you guys. Local U Pull It junk yard is slap out of fuse boxes and says they sell alot of them. Online they are $400. Ugh.
89Suburban
SE PA
Damn bro.
Try these guys by me, I imagine they would ship:
CKendrick
