Brought a new (to me) Burb home
Loki223
Loki223
Elk, WA
Yeah, should be a good rig. After finding the broken bolts we thought about fixing it and sending it down the road, we're into it pretty cheap so we would still come out ahead, the problem is we just like it so much. It's comfy, gets good MPG, especially for the size, and should be all figured out. I will find out for sure next year, i think the AC is going to need something at some point, but beyond that she should be pretty dialed in at this point. And i will likley need to do lower ball joints up front as well, but that can wait for the house to be done. They aren't in "need" of replacement, but more so in a "i should replace it soon" kind of deal. lol
Loki223
Loki223
Elk, WA
New windshield went on the burb Friday, and we found a bad seal on the schrader valve for the AC, so hoping that's the culprit of the AC, but at this point in the year i won't really know until next year.
And thanks to you guys i just ordered Escalade mirrors because my wife and i both hate the low visibility available to us on the stock burb mirrors. And being that i don't want to give up Power Folding, moving to tow mirrors is a non starter.
justchecking
Military
SW Ohio
And thanks to you guys i just ordered Escalade mirrors….
First time i looked at this gen I thought those mirrors looked too small. Then first time i drove one I thought those mirrors ARE small! So that is on my list as well.
Loki223
Loki223
Elk, WA
Yeah, mine should hopefully show up this week, might be able to install soon, might not. Right at the tail end of our house being rebuilt, so the question is whether to use my garage in a couple of weeks and my tools, or use my buddy's garage and have to scrounge for tools since his selection is wanting to say the least....Should be a pretty easy job though. I've been surpsied by the amount of people saying 2-3 hour times on doing it, i was thinking it should probably take about a half hour for both sides realistically. But haven't checked to see how hard GM made the door panels to come off, they are usually pretty simple
Loki223
Loki223
Elk, WA
i'm honestly at a loss as to why people are saying 2+ hours for this, their beer breaks must be epic. it's 2 trim pieces, 4 bolts, and Christmas trees, pull the panel (the video 1A did fully pulled the panel, i'll let mine hang most likely) disconnect the harness, pull the harness retainers, 3 nuts for the mirror, and reverse to put back together. I'm pretty sure i could do this swap faster then the wife takes a shower in the RV.....anyhow. As long as the mirrors show up, i'll get it done in the next week or two
Loki223
Loki223
Elk, WA
Alright, so this might be the last update for a month or two on this little burb of mine. Partially because as mentioned, future upgrades are Christmas presents to me, from my wife, vicariously through me not telling her i bought them. I haven't mentioned the Esky mirrors to her yet, but i drove the burb to work knowing it would be a slow day, and sicne they showed up yesterday i figured i might as well install them. Couple things i remembered while installing them.
#1, Eff GM for their stupid door cards. I've mainly been messing around with mopar door cards for the last 15 years because i enjoy a Cummins when it comes to my trucks. Those door cards, you pull the screws, plastic pop retainers, and life the door card straight up. Nice and easy. I'm not mad about the christmas trees, i'm mad about how much of a PITA it is to get the top of the card seated so you can pop the rest of the card into place. Probably wasted 5 minutes with that on the drivers side. On the passenger side i just popped it loose and did the wiring with the card still hanging over where it hangs to touch the window. was it easier to do the wiring this way? no. Defintiely not. Did it mean i spent an extra 45 seconds on the wiring? yeah, definitely. Did i save 5 minutes wrestling with the panel trying to get it to seat at the top? nope. so totally worth it.
#2, nice wire retainers GM, except that they use tap to hold the wires to the plastic, instead of clippable plastic retainers like FCA which are much easier to open or just pull the harness out. But whatever.
#3, the Esky mirrors are the same width of he Suburban mirrors, but nearly TWICE as tall. Plus they maintain the width while the burban mirrors lose it. 7 1/2 at the widest point on each in terms of width, height the burb mirrors are 4 3/4" tall, compared to 7" tall on the esky mirrors. I haven't even driven beyond moving it back into my spot and there is a HUGE difference. well worth doing.
Oh and #4. to everyoen that took 2-3 hours to do this swap. From the moment i parked the burb, to the moment i got in it to move. Inclduing messing aorund with grabbing the right tools...36 minutes start to finish.....
Height
Esky mirror
OEM mirror
Width
Esky Mirror
OEM Mirror
justchecking
Military
SW Ohio
Height
Esky mirror
OEM mirror
Width
Esky Mirror
OEM Mirror
I get many of my Christmas presents the same way. Thanks for posting this. Definitely a future upgrade for me.
Loki223
Loki223
Elk, WA
After driving it this weekend, zero loss of use on anything. BSM and cross path still works fine, all other functions working fine, completely plug and play being that i went from a full function to a full function swap.
Loki223
Loki223
Elk, WA
So i think my christmas list is going to be...
Morimoto Esky style tail lights.
GM light up grill emlbem
GM bowtie puddle lights
Diode Dynamics 30" stage series LED light bar to be mounted behind the grill....Just need to decide where i want to mount the switch for it. I've already ID"d where i'll mount the light bar itself
Loki223
Loki223
Elk, WA
Ope, and the Moriomto LED Projector fogs. those too
The other thing i'm considering is the LED accent grill light that goes through the center and hits either side of the emblem. But i want to look into that more and find out who actually makes it...hard to spend $200 and get a chinky product with no long term quality
justchecking
Military
SW Ohio
Did you get those on ebay or new?
Loki223
Loki223
Elk, WA
I bought them from ebay
That's the seller i got them from, very well packaged, and honestly came in in better condition then expected. Pictures showed some imperfections in the paint that looked like i just needed to clean and possibly buff them. But they showed up without the imperfections. Looks like they are a wrecking yard back east that puts things up on Ebay. Most of the mirrors i saw on ebay were very expensive, but they had them on around $250 each, so $500 shipped for the pair which was the best deal i could find for a set close to the correct color. I should've looked a little closer, but the color is close enough, just the white without the pearl, and i can live with that. If i can't i always pop the covers off and paint them one weekend
Loki223
Loki223
Elk, WA
Although just saw they are selling tahoe mirrors for $200 each, so i might need to take some pictures of my old mirrors and throw them up on Ebay....
Loki223
Loki223
Elk, WA
So curious if others have ran into this. Driver's side power running board. Bought it with a faulty motor, replaced the motor, worked perfectly for a couple of weeks. Motor shat out, get a warranty replacement from Rock Auto. Well this weekend, i noticed it was making noises and is no bueno no more either. Should i be inspecting something else, or are the rock auto motors just garbage? looks like the brand is AutoTecnica. Doesn't really matter if i can get warranty replacements, if the motor constantly fails
Tahoe14
Central Fl
I would call Rockauto and see what their warranty covers, you could ask them about the quality of that motor and they may or may not give you an honest answer.
Loki223
Loki223
Elk, WA
I've already warrantied it once, both motors lasted about the same time, it's not worth the time to keep swapping them if they just keep failing. I think i'm going to try another source, possibly TRQ, factory ones are uh...whoa spicy pricy
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Did you look on 1A Auto?
Loki223
Loki223
Elk, WA
Yeah, 1A sells the TRQ motors which don't come with the brackets. I'm going to poke my head around under her this weekend and take a closer look to see if i can swap the motor without pulling the bracket, could be an easier swap that way
varminpoolteam
