Dim DIC
bubbz22
I did try searching, and didn't really find help on this. This is on a 2004 GMC Yukon SLT that I just recently purchased.
The DIC is quite dim during the day. Rolling the gauge brightness dial does nothing to change it, but does change the brightness on the gauges.
The headlights aren't on during the day. I didn't see any light to indicate the DRL's are working, but I didn't get out in front of the vehicle.
The auto headlights do work. They're off in the daylight and turn on about 30 seconds after I cover the sensor(or at night), so it seems the sensor is working correctly. The DIC brightness doesn't change at all when the headlights come on.
Does this seem like something that could be fixed by a cluster repair guy? Or is it just that dim and there's nothing to be done about it?
Thanks for any help!
ScottyBoy
Shreveport, La
This is actually a fairly common issue on the GMT800 trucks. It's an internal failure in the instrument cluster. You can "usually " fix it by simply reflowing the solder, and adding a tiny bit more solder to each joint. It's the row of flat surface mount resistors in the cluster that are the problem. They get very tiny hairline cracks/splits in the solder joints and lose connection. It's a pretty easy repair if you know how to solder.
bubbz22
bubbz22
Thank you for the info! I do somewhat know how to solder, but don't know if I trust myself in the cluster. I do want to get all the bulbs upgraded to LEDs and add the trans temp gauge though, so I may just hold off until I get all that done.
ScottyBoy
Shreveport, La
Take this for what it's worth, but I've "heard" that adding a trans temp gauge on a 2003-2004 is really simple. You literally just solder in the stepper motor and swap rhe gauge face to one with the trans temp gauge. You supposedly don't need to upgrade any software or reflash anything in the cluster. The 05 and 06 is different though, it has different software supposedly because they added the tire pressure sensors and the passenger side airbag weight sensors in the seats beginning on 2005. I've been told that 05-06 clusters need the software reflashed when adding a Trans temp gauge.
DRLexpress
Thanks for starting this thread, I have the same exact problem. I'll try to resolder but it might be awhile, a lot of life getting in the way right now.
ScottyBoy
Shreveport, La
Here's a picture of the cluster board, with the resistors circled that I mentioned. Usually just reflowing and adding a small amount of mire solder to these joints will fix the problem. But there's also been instances where the resistors have completely fallen off of the board because of the bad solder joints.
bubbz22
bubbz22
Thank you for your help! This image is very helpful to know what to look for.
ScottyBoy
Shreveport, La
You can also look up "Jeffescortlx" on YouTube. He has a LOT of videos on GM cluster repair, and a few specifically on the issue of a dim or dead odometer and DIC.
Campie
2007 Yukon Denali 6.2 here. Good info but I don’t want to do this work myself. I thought I saw on some thread there was a place you could send the cluster to be redone with LED.
While I’m at it I’ll replace the dash as mine has cracks in the middle and passenger side. I’ll also replace the sensor while I’m in there.
Capybarbro
