slight engine resonance through steering wheel
T
TommyS
Hello everyone, I just wanted to update this thread. The dealer finally had a look at my truck. I have to say, the service manager at my dealership was excellent, and seemed to be a good guy. He and I took a long test drive and he was able to feel the vibration. They took the truck in and removed and tested the front wheels. He said one tested good and the other was way off. After the fix he said he test drove and all was normal.
I pick up the truck and it’s the same crap. No change with the vibration. Service manger said they have some kind of machine that they hook up to the truck to detect and pinpoint where the vibration is coming from. I’m just wondering if this will work or if there is anything else they can check. He said when they had the truck in, everything looks tight in the front. He also told me that it’s not a transmission problem. Don’t know what to believe anymore, but i’m gonna give them another chance before bringing to a different dealer. The truck is totally awesome but this issue is killing it for me. Just wish they could pinpoint this problem the first time.
GMT800 2005 Tahoe Z71
Navy Supporting Member
One the first attempt, did they use this "all knowing vibes detection/pinpoint machine"?
Hell, why not do all 4 wheels?
They did not use the vibe machine yet. they said that’s next.
I hope someone here has heard of or seen, "the vibe machine".
I would wonder why the "vibe machine" was not pulled out of the arsenal to begin with.
This is yet another reason why in my 45 years as a tech/service manager, I never ever wanted to work at a dealer. Fake It Till You Make It.
T
TommyS
UPDATE: Still dealing with this issue. I had the truck at the dealer for a few days, they hooked it up to the vibe machine, and they got back to me today and told me everything is normal. I was in shock. The vibration resonating through the steering wheel is horrible, and they said that is normal for the truck. I have 1800 miles on it!! I told them I was t satisfied and when I went in to pick up the truck, the service manager, and a technician took a test drive with me to see what my concern was. The tech drove the truck and was able to replicate the problem and he said he thinks it’s within the norm for this truck, after the test drive, the service manager pulled out a brand new 2024 tahoe and let me test drive that to see if I felt the same thing. I admit I felt very slight and similar vibration like mine, but still very smooth. Mine is much worse.
I want to say, the service manager is the best I have ever dealt with in any dealer ever. He told me there is not anything else they can do. I’m not sure what to do next. I’m contemplating bringing the truck to an independent mechanic and just pay out of pocket to see if they can pinpoint the issue. Im at the end of my rope
Have you not talked to a general manager or area manager yet? IMO, I have seen where a vibration was very very hard to find and a tech friend of mine said to loosen all the mounts-motor, rack, transfer case, transmission.....etc. and then retension when weight is on all wheels. Have it on a drive on rack. The hard to find vibes was fixed by him. I am just shooting in the dark if you have another tech look at it.
tom3
If that is the cylinder de-activation causing the vibration it might just get worse. Our '19 was really smooth when new, I didn't know it had this actually. After some miles I started feeling it on light acceleration, now at 30k miles I'm feeling it a bit all the time it's on just four cylinders. Starting to worry me too. Wish I'd known about this before we got it. I assumed this drivetrain was bulletproof like the earlier years.
T
TommyS
No, I have not spoken to anybody above the service manager at my dealership. I plan on bringing it to my regular guy who services my other vehicles to get his opinion. I’m starting to wonder if it is possibly the DFM.
T
TommyS
It can quite possibly be the DFM. I already asked the service manager at the dealership if he can turn it off to see if that is the cause. but of course, as expected, the dealer won’t do it. a few other posters in this thread mentioned that it could be the culprit. Not sure though.
Remember, my vehicle was doing this from the minute I took delivery and drove it home. If anyone knows how I could even temporarily shut off the dfm to see if this is the issue, that would be great.
I saw another thread where there is a delete device available, but it does t seem like the kind I can easily plug in under the dashboard. Plus, do t really feel like shelling out $250 bucks for something that isn’t was,is accessible and might not work. Any other suggestions on how to do this? Or is there another, cheaper option?
StephenPT
St. Helens, OR
I don’t have the gas engine (LM2 owner) but I believe it’s been mentioned on this forum before that if you activate the manual shift button “L” and put it into L9 it won’t let it go to 10th gear, but also won’t activate DFM. Worth a try at least…
T
TommyS
Thanks. I did try the manual setting before. Just not sure if I kept it ninth gear. Gonna try this again.
tom3
It should allow you to use all the gears up to ninth in automatic as usual but won't shift into the top gear. I wonder if these ten speeds ever actually use 10th anyway. My brother has a Jeep Cherokee with a 9 speed and it has to be running something like 80mph to go into ninth.
StephenPT
St. Helens, OR
I have a Banks iDash which shows the gear status. It’s not until ~62mph that I see it drop into 10th. Mind you this is on the diesel and it might have different shifting logic on the gas engines.
The diesel has enough torque that when we’re on a road trip going up and down I5 on the west coast I rarely see it down shift from 10th when cruise is set at ~70mph.
Handles the passes well, huh?
T
TommyS
My question is, does anyone know for certain, that when shifting into manual gears shuts off the DFM in the 2024 models?
T
TommyS
My issues is when the truck is revving in the 1500-1800 rpm range. Most of the time I feel the vibration probably in the middle gears, not the highest or lowest gears. I think shutting down the 8th or 10th gears wouldnt solve my issue. If I new a way to totally shut the dfm down, then i would know if that is the problem
StephenPT
St. Helens, OR
In your case I’m not suggesting to use L9 to lock out the higher gears, but because it’s been documented that in that setting DFM won’t activate. You’ll be running a V8 engine 100% of the time and if the cause of your vibration/resonance is DFM then you’ll know on the first drive with it set at L9.
StephenPT
St. Helens, OR
Yep. Between PDX and OLY it never leaves 10th. When we head south and go through Grants Pass then I might see it drop to 9th or 8th during the steep grades. With peak torque at 1500rpm and over 80% at 1250rpm it really takes a lot of grade to force the engine to downshift.
T
TommyS
Stephen, I appreciate the help. I’m gonna try L9. I had read the thread you sent me, but those guys have 2022’s or older. The 2023/24 models were refreshed models. Not sure if the manual setting will work on the DFM with my 2024. Absolutely going to try it though. Sucks that there is no dashboard signal showing when it switches down to 4 cyclinders. I know Range tech is just now introducing plug ins for the 2023 and newer models to block the DFM. Makes me think the software for the newer models are different.
If anyone has 2024 model year truck that can confirm L9 shuts down the dfm, please respond. Thank you.
Hodmjstone
