DFM disabler released
DontTaseMeBro
Some of the 22’s actually didn’t have DFM in them due to the great chip shortage. Not sure how many of those had it removed.
I’ve wonder myself but have been told multiple times that the window sticker would have stated that it didn’t have it. My window sticker says the only things I didn’t get was the 4 way lumbar and parking sensors(which later were retrofitted). So I dunno ‍how to confirm for sure.
CMoore711
Really? I’ve never heard of any of the ‘21+ models not having DFM.
Now there are some that did not have the auto start/stop feature; And for that GM gave the buyer a generous $50 credit and that is usually noted on the vehicles original window sticker.
CMoore711
Not to get off track here but...
Did you get BOTH the 4-Way Lumbar and the parking sensors later retrofitted? Or was it just for the parking sensors?
I have seen quite a few '21-'22 models listed for sale with both of these (2) features mentioned on the original window sticker as not being installed.
Silverado4x4
They do have DFM all the components are inside the motor but they are not activated due to the chip shortage.
Lil Timmy Shy
I've had it on our 2013 for several years and it simply plugs into the ODB2 port and stays there.
We have annual emissions inspections here in metro-PHX, so all I do is unplug it before heading in for the emissions test (all they do is plug into OBD2 port and check for any emissions related MIL codes) and plug it back in when I get home.
No issues to date and our Tahoe runs great with it!
Wouldn't that which you described be the AFM disabler? (Not DFM)
Gearz
It's great they came out with this BUT on my 2011 Range AFM delete it does cause intermittent problems like no crank and power liftgate not to open because it can interrupt the data stream so all I do is unplug and reinstall and I'm on my way but if this causes a problem I have to partially remove the inner fender and the PCM plug which could be a problem if I'm not home or weather conditions are poor. The AFM can also cause a small battery drain so they said if the truck isn't driven for more than 3 days to remove it will this have the same problems that can cause bigger problems? I guess when the public starts to use it we'll find out. :hmmm2:
nick14226
I’m a beta tester, 100% worth it if you’re like me and the DFM causes noticeable lugging/vibration when maintaining speed or slight throttle tip in. I absolutely hate driveability with AFM/DFM on the v8’s. Wifes AFM on her v6 blazer on the other hand, don’t even notice it.
Install was very easy, not as easy as an OBD plug in, but super simple.
nick14226
Their website says this product is designed for "refresh models" in reviewing my paperwork for my 2022 Tahoe, I can see no reference to the word "refresh".
That applies to the pick ups, they changed mid 2022. For SUV’s it’s 21-up 5.3 or 6.2
djnice
Would this disabler allow the DFM lifters to be changed to standard lifters? Since there is no tuning yet for this ecu.
Silverado4x4
No not that easy, DFM lifters require a different cam for that system. Can't install standard lifters on a DFM cam.
djnice
I’m not trying to put together a parts list. I just want to know if the disabler will handle the programming part of the DFM delete. That said, if I’m going to put a new cam in, I’d rather have better performance and then I need a tune anyway.
tom3
Just a side note on those lifters. Seems to me that keeping the lifters pumped up full time would have to eliminate most of the failures we've seen. When those lifters collapse due to the oil cut off all those little internal parts do take a beating. And I wonder why there are no direct retro fit lifters that work with the AFM original camshaft?
DontTaseMeBro
Just the sensors. The 4 way lumbar would have been a $50 credit on the window sticker. It wasn’t. Only the parking sensors were.
14point5
NE Ohio
Apples and Oranges 2013 vs. late model
KC 2013 Tahoe
Chandler, Arizona
AFM cuts off oil to the lifters on 4 cylinders, whereas DFM is a bit more elegant in that it selectively decides which cylinders to cut out. The disabler works on either system, both of which eventually destroy our engines and transmissions in favor of marginally better fuel economy.
Lil Timmy Shy
I understand that. I have a Range Technology disabler. It plugs into the port under the steering wheel (2014 Tahoe). But I think what these fellows are talking about is a new type disabler which requires some additional steps to install. See post #3 in this thread regarding what must be done to install. If I am misreading something, please let me know. Sorry for the confusion.........
KC 2013 Tahoe
Chandler, Arizona
No problem! I can only reference my '13 Tahoe and experience with it. Not sure why they need to cut into their fender liner, but perhaps they're trying to get at the ECU/ICM to get them reprogrammed. I do plan to someday have our Tahoe's ECM tuned to cancel the AFM and also fix an extreme timing retard issue when its above 100 outside (I live in metro PHX). Even with 91 octane Premium and several tanks of Techron the stock ECU retards the timing in hot temperatures to the point where she's gutless accelerating from a standing stop. Below 100, she runs like a dream. Never has been any discernable detonation so hoping the high temperature ignition retard can be tuned-out.
JamesinAbilene
