DFM disabler released
SoloLobo76
I was just looking on their website and saw it available too. Went ahead and ordered one. Hoping it works. Anyone got one and using it?
Micahsd
It sounds interesting…there’s a little bit of an install process removing an ECU connector and fender liner. I was hoping more for a dish connector easy install. :)
Curious how it works out for you. Thanks for the info on it.
CMoore711
This is not only a DFM disabler, but it also disables the auto start/stop feature. This is a great option while maintaining your warranty and to buy time tuning the Global B ECM's becomes easier and cheaper.
umar96
So buying this will protect against the lifter issues? That's the only thing that has held me back from buying a 2021-2024 Yukon or Suburban.
Silverado4x4
No it will not as people have installed it and still had lifter issues back when they had the bad run of lifter issues which was September 2020 to March 2021 engine build date not vehicle build date from the company that made the lifters for GM.
SoloLobo76
I was hoping for an easier install as well like the other ones that go on the obd under the dash. Doesn’t seem that bad though but if there are issues then it’s a pain to remove or check.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I'm wondering if it affects emissions testing VIA the readiness checks like the earlier devices do.
KC 2013 Tahoe
Chandler, Arizona
I've had it on our 2013 for several years and it simply plugs into the ODB2 port and stays there.
We have annual emissions inspections here in metro-PHX, so all I do is unplug it before heading in for the emissions test (all they do is plug into OBD2 port and check for any emissions related MIL codes) and plug it back in when I get home.
No issues to date and our Tahoe runs great with it!
SoloLobo76
If you look at the install instructions this puts a connector device between one of the harness connectors going to what I assume is the control module for the engine. It’s behind the driver side front wheel well liner toward the front of the car. Need to take off the tire and wheel well liner to access it.
Maybe they will make an obd one in the future.
Vladimir2306
It’s just not clear why it is needed. On the 5th generation GM cars, there are no problems with pushers. And in the problems with the 4th generation pushers, no one has proven that the DFM system is to blame. If you turn it off, then by completely reworking the engine, removing it completely, and not an incomprehensible block in the OBD. If you already want to, you can drive in the “Trailer” mode; DFM/AFM does not work in it.
BigdawgR6
What? So is this new for the latest gen? It doesn’t do as described? It doesn’t disable DFM or keep cylinders from deactivating? Are you spreading misinformation on this product or have you seen firsthand info from this product on 21+ models? Can you provide proof on this product and this generation model engines? Not bashing what you’re saying but would like to be educated as I figured this is a new product available to us on the current gen.
Silverado4x4
Go back and read up on the problem with the lifter issue in the date span I posted, the problem with the lifters was not the DFM it was the lifter components were not properly heat treated from the manufacturer that made the lifters so even though if the system is disabled by the disabler the defective lifter components are still there. People have installed the disabler and still had the lifter failure due to the defective lifters.
zbad55
Army
Detroit
This is absolutely correct, it was a supplier spill that wasn't caught and made its way into engine builds. Nothing to do with DFM,
BigdawgR6
Would this still be beneficial for those who haven’t had issues with lifters or aren’t plagued with defective units? I would hope it would help with longevity of the components down the road.
Silverado4x4
Don't really know. My neighbor has a 19 silverado with over 80,000 miles on his DFM he doesn't have the disabler and not a single problem but most people get them when they install an after exhaust system because when it goes into cutting back cylinders they get that helicopter sound and is really annoying.
tagexpcom
The "Trailer Mode" disable a few comments ago was interesting. We bought a used 2021 Yukon 6.2L/10-speed a year ago with 49K miles (was from Hertz). We bought it to tow and most of the 5,000miles so far are from towing - e.g. 'tow mode'.
I tried the 'manually set to 9th gear' and it didn't make any difference (I can tell) in the engine/drivetrain operations and this has to be done each time one drives. Installed that common auto-stop product and it works great.
Not bashing! but have been following the DFM discussion and like someone above, wondering if this is worth installing since we're up to 54K miles with no issues. Maybe our's didn't have the suspect lifters and is past the problem point? Also, the rig performs very well - we Love it - as is :)
DontTaseMeBro
Here’s where I’m at: I don’t notice or hear DFM in my 2022(had its engine replaced in ‘23) at all. I installed the auto stop/start eliminator and have been very happy with this engine. If I do end up buying this device, it’ll be after the power train warranty is up.
Micahsd
Some of the 22’s actually didn’t have DFM in them due to the great chip shortage. Not sure how many of those had it removed.
BadDaddy2003
