2015 Yukon to Escalade mirror swap, general mirror question too...
Kelleytechh
So first off from what I have read DL3 mirrors are the premium Tahoe/Yukon mirror power-folding, heated etc. The DL8 are more basic. I will add info I found at the end for reference.
I have a 2015 Yukon SLT with DL3 mirrors. I would like to upgrade to Escalade mirrors simply for the bigger mirror. There is a lot of info on going basic mirror (DL8) to Escalade but haven't seen much on the DL3 upgrade. Are there switch issues or wiring issues? Is there a code for Escalade mirrors i.e. DL3/8 for different options? Thanks in advance all!
reference info:
Mirror Types:
DE2 Mirrors - These are the basic mirrors found on W/T Trucks. They do not have power anything. They are manual adjust, manual fold, etc.
DL8 Mirrors – These are the most common mirrors found on LT/SLE trucks and are the next level from DE2 Mirrors. DL8 Mirrors are Heated, Power Adjust, and Manual Fold. If your truck has 1LT/2LT options, this will most likely be the same mirror.
DL3 Mirrors – These are mirrors are the “Premium” version to the DL8 Mirrors that most folks are wanting to upgrade to. These mirrors are typically found on your higher trim LTZ/High Country and SLT/Denali trucks. These mirrors are: Heated, Power Adjust, Power Fold, Turn Signal, Puddle Lamps, and Auto Dim (Driver’s Side).
Towing Mirrors – These mirrors are the larger mirrors designed to help with towing. These mirrors can be found as options in some 2500/3500 Heavy Duty Trucks. They come in (2) main flavors.
  • DPN – These are Manually Folding, Manually Extending, Heated, Turn Signal, Cargo (also referred to as Courtesy Lamps), and Clearance Lamps (also referred to as Park/Running Lamps)
  • DQS – These are essentially the same as DPN except they are Power Folding and supports Mirror Memory if your truck has this feature.
RST Dana
OH
Plug and play. I’ve done this on 3 vehicles. Bought all mirrors from eBay. Read the specs carefully. Some will have no puddle, no blindside or the language NOT English. Sometimes you get B lucky with cover colors too.
K
Kelleytechh
Awesome, thanks for the info!
2fatowing
stop it.. this is a thing?!?
Loki223
Elk, WA
And suddenly i need to spend more money. I hope you are happy @RST Dana Do you have some pcitures and comparisons on the Escalade vs Suburban mirros? i've been looking for Tow mirrors with power fold, but haven't found any. I hate how small the mirrors are on my 2015 LTZ Burb, would be nice to get some bigger mirrors, so curious about how much better they are
Loki223
Elk, WA
You need the DL3 for power folding and BSM i'm pretty sure. Just found a set of pearl white ones on ebay, $500 for the pair, but quite frankly, i hate the stock mirrors on the burb so i just gave myself something to do once they get here
found this thread that has more info on them, looks to be a huge difference in mirror size and visbility
RST Dana
OH
And do DQS have blind spot warning?
What? Mine have BSM, heat, turn signal and power fold. Cameras too, but I don’t have a solution for those.
brice715
