*SOLVED* 2018 Tahoe P135a help
ConquerCustom
I have a 2018 Tahoe with a P135a code. It’s only running on the passenger bank.
I checked all the fuses, they look good. I checked the voltage at the plugs and while running, the far left plug (pin 4) is over 12v the other 3 are grounded.
I unplugged 1 from the passenger bank while it was running and it read the same so I guess the power at the harness is correct?
For funsies, I put my spark test light on and the coils are definitely firing the drivers side.
Now I’m stumped on what to check next.
Welcome to the Forum from NH.
Pics of the truck, please.
I cannot personally assist you with your issue, but other members of this Forum much more knowledgeable than me in this area will chime in.
GMT800 2005 Tahoe Z71
Navy Supporting Member
No one chimed in but I figured I’d drop back in to share the source of the issue.
The ECU failed and was leaving the circuit open for bank 1. So I had a dealership install a new ecu and program it.
Sometimes, when you are a new member, it is best to introduce yourself first, in Introduction, because some members get turned off by a new member only joining to get help.
Then find the correct section and post the problem there, like you did.
Plus, you posted at the start of a holiday weekend.
dizhai
