Window trim
blkonblk
NYC
hey fam - looking to replace my Yukon denali chrome window trim with black. Ordered the parts and they are on their way. Anyone done this? any tips how to remove the current ones?
blkonblk
blkonblk
NYC
nobody replaced these? any ideas anyone?
Cleach
You can buy the pieces on GMpartsdirect.com. I'm just wondering how the install is.
If they are like the 07-14 they just slide off and new ones slide on. easy peasy, just takes a plastic trim tool to lift the edge up on the end and pull it off.
blkonblk
blkonblk
NYC
just started and this isnon the upper right, anyone know how this comes off? does not seem like a screw but now sure. Anyone know?
Looks like a rivet, so probably have to drill it out and get a rivet tool and rivets from the auto parts store to insert a new one after you replace the trim piece.
if you try to pry it off it's going to damage the hole the rivet goes it
I would just drill out that center hole, go slow once it gets right about 1/4" or less it should just fall apart
91RS
GA
Most people are cheap and have them wrapped rather than replacing them. I think most of them pieces on this body style have rivets, so you’ll have to drill those out and put in new ones.
KMeloney
What?! I wouldn't be drilling anything out of my truck for trim replacement.
What's the back of the new trim look like? It certainly doesn't look like that riveted piece needs to come out (unless you guys are suggesting that the trim was riveted in place from the inside of the body)...
factory rivet the only way to remove it is to drill it out and install a new rivet, otherwise if you try to pry it out it's going to damage the body and rip a big hole.
won't hurt anything to drill it just enough to break the rivet open.
and these rivets install with a tool from the front (one way/pop rivet), not from the backside, they work sort of like a drywall mount
KMeloney
Got it. But did the OP break something taking that trim piece off which left a rivet behind? I just can’t imagine that that trim is riveted in place. Just seems crazy and un-GM-like. I would have bet it was 3M-taped in place (like everything on my ‘09 Tahoe).
LOL, well unless I am seeing things that looks like the trim piece is riveted on I guess GM got tired of replacing the ones that just fall off
KMeloney
...But we're not looking at a TRIM piece that's riveted to the truck, right? Aren't we looking at what's probably a trim RETAINER PIECE that's riveted to the truck? Trim was clearly covering that piece. So, unless that piece was part of the trim, and the OP snapped it off the back of the trim, then I've got to believe that the new trim clips into that retainer.
I remember that on my '09, the tail lights had metal posts attached to them that pressed into plastic retainers (that pressed into openings in the sheet metal). When I removed my tail lights to replace them with aftermarket ones, the plastic retainers stayed securely in the body. The new tail lights came with those same plastic retainers already attached to the posts. After fretting for a second that I'd have to somehow pry the existing plastic retainers out of the truck in order to mount the new lights, I quickly realized that all I had to do was instead pull the new lights' ones off the posts, and push the posts into the existing retainers.
This LOOKS like a similar situation to me (but maybe we don't have all the information still).
possibly but one would need to see the new trim piece to tell or not
CMoore711
As previously mentioned those are for sure rivets and you will re-install the OEM black window trim with rivets also.
I had OEM Suburban RST window trim pieces installed on my old 2015 Yukon XL Denali and there were rivets used on the K2XX 2015-2020 GM SUV window trim.
Additionally, it's worth mentioning that replacing the window trim pieces also required me to replace the vertical black plastic appliques on the doors at the same time in order to properly remove and re-install the window trim. This may or may not be the case for the '21+ models?
blkonblk
blkonblk
NYC
ok fam, was on vacation for a few weeks and came back last night. got up bright and early this morning and finished replacing everything. all the rivets had to be drilled and replaced
KMeloney
That's insane. I still can't picture why.
But let's see some damn pics!
scottd
