Front coil spring
DD0621
I have 2011 Yukon Denali that I just lowered with spindles and the front strut, but not the whole assembly. So I still have the stock auto ride spring. I want to get a stiffer spring to get rid of the bounce of the front. Can anyone recommend a good spring that will get rid of this bounce? Another question at 60-75 on the freeway there is so much shacking that it is unsafe to drive it at that speed. I had the front end aligned and its all good there now. Will a stiffer spring help that or should I look and doing a new sway bar or is there something else that will help with this? TIA
mountie
The bounce is usually due to a weak shock absorber .. (?) Maybe the shocks / springs are not matched ?
D
DD0621
The bounce is usually due to a weak shock absorber .. (?) Maybe the shocks / springs are not matched ?This is the
This is the kit I did. MaxTrac KS331234S Lowering Kit 3 in. Front Drop 4 in. Rear Drop Incl. Front Lowering Spindles Adjustable Lowering Struts Rear Lowering Coils Shock Extenders Sensor Rods Lowering Kit
It came with new front shocks. Maybe I need to look at a different brand. I would guess the spring rate for the stock auto ride spring would be different than a non auto ride spring.
mountie
Someone can correct me, but some factory 'auto ride' , 'air adjust', manual auto level ( Nivomats / Sachs) shocks require a softer spring, since the shocks add SUPPORT to the suspension, so those coil springs are softer ) ... Check your RPO codes )
D
DD0621
That is what I have heard, but have not seen what people are replacing the springs with. I have been looking at possibly ordering 1500 truck springs to see if they will fit. I have tried inputting the vehicle into numerous sites without air ride option just to see if I can find a spring that would fit the strut tower without having to replace the whole tower. I know there are a lot of options for the whole tower but don't want to go that route since I already have a new shock.
mountie
Do what I did..... 1st, I found the original sticker - part # attached to my coil springs... Go to your GM dealer with your VIN# and they can show what you should have as stock..... and maybe find a spring for your model, but with the standard coil, and compare that to the coils you have to match with your shock. I found, most shock absorber sellers actually don't have a clue what spring should match the shock you are looking at to buy. ( Don't be fooled by a 'neat looking' website....)
A good looking shock seller brags how a 'performance' shock they sell is great for a rough road or for off-road.... REALLY ??? I drive a *****'n Yukon XL.... Not a Hummer !!
mountie
Spring change for active suspensions (Z55 or Z95) versus passive suspensions is for the rear springs only, as I understand it.
As @mountie stated above, bouncing is typically shock related and not spring related.
mountie
A few weeks ago, I was driving on the freeway, going about 75 mph ( cruising north from Fort Lauderdale).... A late model Escalade was 'cruising' in the center lane.... The front end was bouncing up and down, on the smooth road.... I wonder what caused that???
Totally blown front shocks, IMO.
waveryd
IL
I am dealing with a similar situation on my 2014 PPV. I just used Maxtrac struts, their 2" drop spindles but used my stock front springs. I think the springs are too stiff for those struts. I'm going to research further and try to find some softer springs for the front. I used Maxtrac rear springs and shocks on the rear and they seem evenly matched but much softer than the PPV set up. I actually got a net drop of a little more than an inch on the front which to me is another clue that the stock PPV springs are too stiff for their struts.
mountie
YUP...
petethepug
Michael
SoCal
One day these aftermarket companies selling junk and exploiting our sweat & labor will get their due.
justinakay79
