Thoughts on adding to rear suspension?
Jhelton
Thoughts on adding these to rear and using compressor to air up when needed? https://www.ebay.com/itm/1964710865...TeorFFsRQe&var=&widget_ver=artemis&media=COPY
I'd have to get some feedback from an actual user to get quality info on the shock part of the product itself. With 753 reviews, you should be able to get a feel for that.
olyelr
Elk Rapids, MI
Why not just get these when they are back in stock?
It’s certainly an option. But a higher ride height and stiffer ride when empty may be something that comes with those.
Trey Hardy
What manual airbag works with the IRS for the 2021+ models?
i think rough country actually has a setup I may be wrong I think they got everything but the brackets but I’m sure any good welder in your area could make you some pretty cheap
olyelr
Elk Rapids, MI
That just made me think…those aftermarket airbag struts posted above most likely have no electronics for the mag ride. Not sure on that though. If not, then that would be another hurdle going that route to keep all the lights off on the dash.
I take that back…just read the magnetic part in the description haaaaa.
J
Jhelton
Yes- for the times the rear end sags with weight it would be nice to level it out.
djnice
Seems like all you need to add to those is some fittings and an air hose with shrader valve. You could look at air bag assist kits for other vehicles and see what all they come with. Is an air filter or anything needed, etc.?
You might try posting in the street suspension section where you get people using air to lower their rides.
I am pretty sure there is already a hole in the top of the tower for the air fitting, but you could check first and if not decided if you want to drill it.
Tupapi
