Auto fog light option on Yukon
Edlee321
is there any module or rewiring i can do for fog light to automatically turn on with DRL on Yukon?
CaptainMurray
Find your car here.
AliBaba
Seattle, WA
Nothing yet that i have seen. I’m looking for that AND fog on with high beams. I’m not about cutting into factory wiring so patiently waiting for a plug and play option.
ssraccent
I just finished installing a home auto fog kit for my yukon denali xl 2023. Really easy with two #1N 4004 diodes. From connector X1 wire 1 yellow to connector X1 wire 3 brown and gray for the left side. Then connector X3 wire 4 yellow to X3 wire 2 brown green for the right side.
With this method, during the day the fogs are off but in the evening on low and high beam the fogs are still on.
Sorry for my english
JayceeP
Super annoying the fog lights in my SLTdon’t stay on automatically once the fog light button is pushed. Never had this issue before in my F150, 4Runner, or Jeep lol.
BobHolthaus
Okay gentlemen, I found a provider for plug and play solutions. @Gen5DIY will make a harness for you. He did my reverse lights harnesses last year; he’s making some for my GFs new 1500 Sierra. Anyway, he said for $190 he’s going to make me a harness that will cause my fog lights to come on any time the lights are on, and will not turn off with the high beams. Any time I turn the lights on (or they go on automatically), fog lights will be on. This works for me. Give him a shout; he has a website of the same name.
KMeloney
That’s great. Though I haven’t actually installed it yet, their radar detector mirror-wiring plug kit looks very well made.
BobHolthaus
His reverse light wiring for the Yukon was perfect quality and looked very OEM.
KMeloney
Any info yet on exactly how/where it will install? I've got the Autostop Eliminator behind the panel with the fog light button already... I'd imagine there's still room for another harness behind there, but... Thanks again.
KMeloney
FYI, I lied about the location of the Autostop Eliminator wiring. It went behind the panel ABOVE the 4-wheel drive selector and lights switch panel in my ‘23. Haven’t removed the panel with the fog light switch in it yet, but I’m assuming it’ll have to be removed for this harness.
BobHolthaus
Reply from Gen5DIY on where the harness would go:
It will connect inline at the passenger side headlight and then inline at the body to bumper harness which is located right above the passenger side fog light
KMeloney
Hmmm... Ok, think you could confirm one more thing (for now) for me/us? I've got the illuminated GMC grille emblem installed on my '23, and I believe that it gets power from and plugs into a harness near the DRIVER-side fog light... This foglights-on harness would definitely plug in on the passenger-side and not interfere with either the Chevy or GMC illuminated grille emblems' wiring/operation?
Thank you!
BobHolthaus
Thank you!
Your reply has been sent
BobHolthaus
Thank you!
His direct answer was: "It will not interfere". The email is [email protected] if you have any more questions. Thanks guys!
ScottS-Michigan
