2011 Tahoe Android radio swap
hillstrubl
Picked up a chinese Android radio that supposedly is a factory fit. Install after laying everything out and pulling off the trim was quite easy. The issue (apparently known) is the rear has a buzzing and very little sound coming from the speakers. Its almost like all of the sound is bridged to feed the front only (which sounds great but is VERY loud). I'm being told to cut a specific wire while I'll try tomorrow. If it works, this is a great upgrade. The interface is quick (despite having only 2GB RAM) and Android Auto (wireless) connected immediately.
Amazon link -> https://www.amazon.com/dp/B0CM6HC5W6?ref=ppx_yo2ov_dt_b_product_details&th=1
Some pics, I'm not going to put the dash back together until I know I'm keeping it, etc
(Support says cut the brown wire on Harness labeled "2")
hillstrubl
hillstrubl
**Update** can't get the rear speakers to work, but went back and forth with support trying 2 or 3 things, apparently I missed a harness to harness amp trigger wire (not sure why that's not presoldered but whatever). Will re-re-swap tomorrow and report back.
hillstrubl
hillstrubl
**another update** amp trigger wire re-attached, now as soon as its powered on a LOUD buzzing plays over the rear speakers. Spoke to support again and they're sending me another radio. Swapped back to the factory radio and all works (so its not the wiring or amp). This is frustrating... I might end up with a name brand Pioneer, etc
tooleyondeck
Northwest FL
Do you have one or two to recommend?
BOSS Audio has some cheap options:
^^ I have 2 of these, one in my 03 Denali and one in my daughter's Mazda
^^ This one has a full 7" screen and a 5 year warranty
B-train
I like that the radio has the factory look. Keep us posted. I've been thinking about the same idea.
hillstrubl
hillstrubl
This was a hail mary, as the feature list is great. I received a replacement radio (same model) and have the same exact issue. I'm giving up and ordering something from crutchfield. I solved the humming and buzzing, but can't get the amp to wake up for the rear speakers enough to have anything but VERY low volume.
**Update** just ordered this
Gearz
I installed a Phoenix 13” radio plug and play and it has better sound than the original one. $550 on sale . Just google it. There is a learning curve but I’m very happy with it. No buzz and retained most all features in including the back up camera.
enginehead
if you look at Crutchfield.com, they show there are adapter kits for vehicle with the Bose audio systems. you can go to their site and buy just the adapter kit if you need to.
I am not a fan of those generic after market andoid radios. I installed a version of this Sony unit in my parent's 4Runner and will probably put this in my Tahoe
hillstrubl
hillstrubl
Good luck on your project, hope the new unit fixes it.
New unit was exactly the same, can only get a tiny amount of sound from rear speakers and if the amp trigger wire is spliced together it buzzes LOUD the entire time it's powered on.
tooleyondeck
Northwest FL
You should be happy with your crutchfield unit, did you take advantage of their ready-wire service by chance? It was worth the $25 to save me a bunch of splicing and soldering.
TollKeeper
Brighton, CO
Have you looked into Atoto? Know of a couple people that have them, and love them.
I am looking at getting the Atoto S8 Ultra myself.
hillstrubl
hillstrubl
I think I will, I've had good luck with Crutchfield in the past. I did have them build the harness for me, $25 is well worth it. I will have to cut 1 wire though to ground out the parking brake trigger wire.
hillstrubl
hillstrubl
Initially yes, but the lack of volume knob was the dealbreaker
hillstrubl
hillstrubl
Crutchfield "Dual" branded unit in. Its very basic, which is exactly what I wanted. Basically its an AM/FM radio, reverse cam and vehicle to use Android Auto (wireless). Works perfect.
I also rewired both front power plugs with relays to be ignition switched (changed out the drivers side one for a QC/PD flush USB port) and added aforementioned camera. All in all, very happy, sounds great.
Malii Denali
Boston
Looking to swap my factory boss with nav and res…. Were you able to get crutchfield to provide you a solution that retains everything?
Also how do you like that Dual head unit?
Towmaster
