Squeaking noise STILL driving me crazy
iboughtatahoe23
Hi. I posted a month ago about this really irritating high-pitched squeaking noise from the front left wheel. It’s been going on for about six months. I took it into the shop. They said they couldn’t find anything wrong with it and sent me on my way. Today it’s really bothering me. It seems to happen under 20 miles an hour and goes away when I go over I swear that something is dragging on the rotor because that rotor is hotter than all of the other ones. I know that I lick my finger all the other rotors and they didn’t sizzle, but the front sizzle as soon as I touched it.
I’ll leave a video below and I would really really appreciate what I should do. I don’t own a jack. I know they are cheap at Harbor freight but floor jacks are not cheap and you need that to lift up the vehicle in order to set it on the jackstands, correct?
Video of noise. Link take you to streamable.com
Geotrash
Dave
Richmond, VA
Only 2 places up there that will generate enough heat to sizzle spit: brake pad friction on the rotor, and failing wheel bearings. Given that your sizzle is when you touch the rotor and it's very unlikely that a failing wheel bearing would get the rotor that hot, I suspect you're looking at a sticking caliper.
Trey Hardy
I got the same issue but mine is the guide for the brake pads I bent it by mistake and it rubs the rotor after driving a lil bit and then makes a consistent squealing noise
GMT800 2005 Tahoe Z71
Navy Supporting Member
Listened to video and could not hear a squeak noise. Based off of what you said, does sound like a stuck caliper piston or a brake hose breaking down on the inside.
iboughtatahoe23
iboughtatahoe23
Popped wheel off. Seems like rotor turns free for 9/10 of the rotation than it very slightly binds. I don’t hear the squeaking noise really. I hear something
https://streamable.com/lito1m
brice715
