Bridgestone tires. good or bad? My experience.
tjs3922
Just replaced my Bridgestone Alenzas 275 50 22 on my 23 Yukon XL. 10,000 miles on them down to 5.5/32. I had a flat in one on the sidewall, so once I looked at them I was like, Ugh. Replaced all 4 and be done with them. Went with Pirelli Scorpion +3. Good looking tire.
Odd, my other Yukon has the Bridgestones and at 4,000 ,miles look brand spanking new.
Any opinions on these stock tires. I had no trouble with them on previous Suburban and Yukons.
B-train
Mine came with the 285-45-22 Alenza tires. I can't say much good about them. They wear quickly and perform ****** in conditions other than dry once they get worn down. I won't be replacing them again.
I have, however, had good luck with Bridgestone Dueler tires of the 18 inch rim size on my older Yukons. My 2017 will most likely get 18 or 20 inch wheels and different brand tires when this summer season is done.
UsualSuspect
SoCal
Our Yukon has 18,000 on it, plenty of tread remaining, they are 275-50-22. Most of the miles are highway speeds, 75-80, no flats, no abnormal wear, no balance issues, so far problem free.
wjburken
Eastern Iowa
On my 2007, 2008 and 2013 Yukons, I averaged 80K+ on Bridgestone Dueller H/L Alenza's over the course of multiple sets. They handled Iowa snow just fine.
Tire Rack lists a few versions, but I have always gone with what they list as the OEM one.
That being said, I seem to be in the minority when it comes to having good things to say about Bridgestone. A majority of folks here are big on Michelins it seems.
Banks22
Michigan
You should contact the gmc dealer and Bridgestone and you may be able to get compensated for “faulty” tires. My mother in law had shit tires on her equinox that wore very fast and she got credited some money by the manufacturer.
chris s
As has been said previously, the Bridgestones on my Yukon wore out quickly and lost a lot of performance from new very early on..I replaced them with Michelin Defenders and have noticed a better and more quiet ride with better wet performance
Stbentoak
They suck plain and simple. They are like taking your life in your own hands in a rain storm. I’ve muddled through them for the last three years to try to get some good out of them, but within a month or so they are going bye-bye…. summer rains are coming and I am not going to have these things on there.
Micahsd
My ‘21 Tahoe had the Bridgestone 22” tires…they were garbage. Just driving around in drive pavement they’d chip or skip a little.
Also had one of them get cut within 500 miles so the dealer replaced it for free under goodwill and another one had a nail in the sidewalk at about 10k miles. I did have an alignment done under warranty as the steering wheel was off a little.
I made it about 28k miles (maybe the alignment helped to make it that far) and replaced them with Pirelli tires through the GM dealer as they gave me a better deal than other places and had a $120 rebate. Also got an alignment so hopefully they last longer.
bill1013
Air Force EMT/First Responder Firefighter
Waianae, Hawaii
You get what you pay for. The tires that come with the vehicle, car or SUV, are basic crap tires. If you get 10K out of them you’re lucky. Low end, basic tires are just to get it off the lot and down the road a ways. I always go with premium, high quality tires. In the long run they last longer, are a better, safer ride and the warranty is usually better. Getting them from a reputable tire dealer strengthens the deal. “Spend a little extra and get the GOOD STUFF”.
91RS
GA
They are garbage. Once you buy Michelins, you’ll know just how bad they are. I used a set of the Dueler Alenza to test fit some wheels and that garbage came right back off the next morning. I thought my truck was going to roll over on the highway entrance ramp.
tom3
I wonder if those Bridgestones were energy saver tires? Those have about 8/32s tread depth new. Pretty much at the required replacement depth for a leased vehicle turn in I think. Hard to beat premium Michelin tires for sure.
Vinnoto1
The stock bridgestones suck, horrible traction and wear. I have Michilin Defenders on my wife's yukon and there is a night and day difference with these two. I can't wait for mine to be replaced with the defenders as well.
mwswarrior
Dallas/Fort Worth Texas
I haven't typically gotten more than 30 to 35K miles on stock rubber. They put budget tires on at the factory for the most part and you can do MUCH better with a little research on Consumer Reports or TireRack.com. My second set on my '19 Tahoe were Continentals that lasted around 70K miles. I put another set on for the next 70K. We're at 130K and they look great!
wilcfr
I have had Nitto Grapplers on a 2004 Tahoe and loved them. I put them on my 2010 Explorer Express van after a bad experience with wear from a set of Yokohamas and loved them. I now have a set of Nitto Nomads on the van and love them. Obviously, I like Nitto tires. The Grapplers have a pretty aggressive tread but are reasonably quiet on the road and give great traction in loose sand, light mud and snow. The Nomads are quieter, handle a little better and still give you very acceptable performance on most terrains (Going to a secluded flyfishing site, trailhead or campground), and in any weather condition. I got 50K out of my last set of Grapplers on a heavy AWD conversion van and only replaced them because one had a mysterious slow leak that no one could trace. They still had probably 10-20K left on them.
dbphillips
Huh, I think I will avoid replacing with Alenzas when it's time, as they seem to vary waaay to much. We are at 30k, with 20k of towing and ours are still great. They aren't the best traction in wet, but it's the first set, so I can't tell if it is the suspension or other characteristics of the vehicle itself. They are definitely great in the dry when not towing.
rswaug
We've got just shy of 12K on my wife's ride and they're only showing minimal wear. I just had them rotated for the 3rd time when it was serviced last week and I was pleasantly surprised when the tech was going over them. My wife isn't easy on it by any stretch either. When I got in it to wash it yesterday morning, the 25 mile average was at 11.7 so I know she's not unfamiliar with the gas pedal.
Deuce16GMCs
Ok...so this has everything do with how sensitive you are to vibrations.
I've had Bridgestones come stock on every vehicle I've ever owned. Every single one of them has experienced vibrations with the exception of 1. And that was my Tahoe with the air suspension.
On every single one, I had the BS road forced balanced. And they consistently balance at 20-40 lbs of Road force. In nearly 16 years. I've never had a single BS balance below 20 lbs. Everyone has given a oscillation type vibration.
As soon as I switch to Michelin Defenders, my road force drops to 12 lbs or below. The vibrations are gone. Every single time. All my Foreman's, master techs, shop managers, etc...all immediately swap their BS for Michelin.
And if anyone remembers the whole issue with the roof cross beams were separating on the 2015-2017 Escalades, Suburbans, and Yukon XLs, dealerships were swapping BS for Michelins to reduce the impact on the roofs.
But as I mentioned. Folks that are not sensitive to vibrations seem to have no problems with BS. So YMMV. But for me, the BS are crap.
Skeeter
I can't say anything good about the 2 sets of Bridgestones I've had. One set on my old Montero Sport had a shimmy after 35mph. Costco rebalanced them twice with no effect. After they remounted and balanced did the shimmy get reduced but never went away. They did wear well, I go to 40k miles when I got a nail in the sidewall. I replaced them with a cheap set of Nexen which rode perfectly (no more shimmy). I got my wife a 2017 Subaru which came with a new set of Bridgestone Ecopia.s. The ride seems harsh and are very noisy on old asphalt. I picked up a 2007 Denali 3 years ago that came with 22" Falken's. They ride great, quiet, and after 20k I can't see any wear.
CaptainMurray
ON my old 2007 Tahoe 250K and my 2020 Yukon 60k always used Michelin LTZ. Currently have 60k on them with probably another 10k before needing to replace them.
BadDaddy2003
